Rear brakes... grrrr
Old Jan 17, 2006 | 05:23 PM
Coda's Avatar
So I finally got sick of using needle nose pliers to spin the girling caliper and went and bought the tool. So, I started tearing everything apart again, all was going well. I then put the tool on a 3/8 to 1/4 adapter and inserted it into my cordless. I began spinning the caliper in. After what seemed like a good while I tried installing my new pads and putting the caliper back on the rotor. No go, still to tight, so back to the drill I went for another what seemed like an eternity. Again tried the caliper and new pads..... no go again, it's getting dark, frustration is setting in. "Why did I buy a Jap ride" I found myself asking. So, I decide that I'll re-install the old pads and have another go at it tomorrow when I can see. Low and behold, these won't go back on. Now anger is quickly replacing frustration. I decide I'm clearly missing some magic point about Mazda girling calipers and come check the board with the seach function.. doesnt seem like there are any threads discussing this problem my brakes are having. So I go out, cuss the car up and down, put the drill back on the caliper for one more go, almost put the old pads on and decide F this, I'll try the new ones one more time. BINGO! They now work. Tomorrow I'll do the other side when I can see again, but I find myself asking the question, was it checking the boards for guidance that made the Mazda Gods shine down on my car, or was it cussing it like I have done to every other vehicle I have owned that made it miraculously decide to cooperate.
Old Jan 17, 2006 | 05:30 PM
BlueEyes's Avatar
It was me.
Old Jan 17, 2006 | 05:32 PM
Matt RX8's Avatar
I think one side might screw in counter clockwise and one side screws in clockwise.
Old Jan 17, 2006 | 05:38 PM
moRotorMotor's Avatar
Rotary eXperimental-8
Old Jan 17, 2006 | 05:53 PM
MadDashRX8's Avatar
Resu Deretsiger
Personally, I don't believe my 8 has girlie brakes. Front OR rear.
But seriously, are you speaking of the caliper component that rests behind the inside pad? Circular in shape, yet open in the center? I'm clueless what "girling" is.
Old Jan 17, 2006 | 06:00 PM
Matt RX8's Avatar
I wouldn't use the powertool on the rear brakes either. You could over tighten them and tear a hole in the rubber caliper piston boot thing.
Old Jan 17, 2006 | 06:14 PM
woodysjh's Avatar
I already searched!!!!!!!
Should use a C-clamp and push the piston in so you have more room for the pads. That way you do not have to bleed your brakes.
Old Jan 17, 2006 | 06:18 PM
Section 8's Avatar
Mazda rear brakes cannot be compressed in a standard method. I suspect that the RX8 has similar rear calipers to my RX7, which require a special tool and a clockwise rotation to compress the cylinder.
I've never had any problems with the rear calipers on my 7, hadn't had the 8 long enough to do brakes yet.
Old Jan 17, 2006 | 06:19 PM
Section 8's Avatar
Also, make sure that the cap to the brake fluid resevoir is off when you're compressing teh cylinder and that you keep an eye on the fluid so that it does not overflow.
Old Jan 17, 2006 | 06:34 PM
Budweiser8Jr's Avatar
The caliper pistons are threaded. They require a special tool that is available at AutoZone for renting. My 1999 Honda has the same brakes. Once you get the tool, compressing the piston takes about 1 minute.
Old Jan 17, 2006 | 06:59 PM
BlueEyes's Avatar
A Girling caliper, I believe, is as has been described above. Requireing a special tool to compress the piston. He isn't calling the calipers girlie
Old Jan 17, 2006 | 07:50 PM
Coda's Avatar
That is correct... got my first introduction to them while showing a buddy how to replace pads on his GTI a couple years back. I expected them, as all rear disc brakes I've worked on have had this feature, I suspect they have something to do with the parking brake. It's just that my Super Duty's weren't near the PIA that these were.
Old Jan 17, 2006 | 11:14 PM
Matt RX8's Avatar
you rent the tool? the little tool only cost about $3.
Old Jan 18, 2006 | 10:14 AM
Section 8's Avatar
where at? mazdamotorsports wants $30 for the tool for the FD rear brakes.
Old Jan 18, 2006 | 11:24 AM
Matt RX8's Avatar
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
well here it costs $6. but I think you can get the same thing at Sears for $3-4.
more info here.
https://www.rx8club.com/showthread.p...DIY+brake+tool
Old Jan 18, 2006 | 12:11 PM
Coop '04's Avatar
DELIVERED 07-17-2004
4.00 at Auto Zone, and 4.50 at Oreilley's. No a drill is definitly not the way to go, I suppose you use a pipe wrench on your lug nuts. It only takes a few turns, it's not threaded either, it's notched. The reason is so the parking brake stays adjusted. As the piston moves out it rotates and ratchets at the same time. The tool is a cube and actually has 6 different configurations for the pins that stick out depending on witch surface you apply toward the piston.
Old Jan 18, 2006 | 12:30 PM
Coda's Avatar
A drill was most certainly the way to go for me... obviously there are different ways to use a tool. If you don't understand the operation of the tool I can see where there could be a potential hazard. As for a few turns, that was certainly not the case. It was what I expected after previous experience, but a LOT of turns did not get it done, so I resorted to a power tool, and will do so again in the future. This is far from the first vehicle I have worked on. 4x4 suspension swaps are more common for me, so a brake job isnt something that is a challenge. Appreciate the concern however. I'd hate to see someone spin it into a disaster.
Old Jan 18, 2006 | 12:40 PM
Coop '04's Avatar
So a pipe wrench on lug nuts is not that out of line for you...given your 4X4 experience...
Old Jan 18, 2006 | 01:35 PM
Joe_914's Avatar
I don't get it. you pay near 30K for a car and then complain about a 30 dollar tool?
Having wrenched on my "other" cars I learned that the right tool is the way to go. Less broken stuff and usually works better.
Now try to find a flywheel lock for a 78 Porsche 928 on a Friday night. Oh sorry sir we are going to have to special order that..... What's it for again?
Ahh never mind... 1-800 $$$-$$$$ Hey man you got a factory tool for this. Yea send it to me ASAP. I know you already have my Credit card #
Old Jan 18, 2006 | 03:54 PM
Coda's Avatar
Not sure if this is directed at me, but I wasn't compaining about the $10 tool, I can now use it on my other vehicles. More just the story of the aggravation.
Old Jan 18, 2006 | 03:56 PM
Coda's Avatar
Pipe wrenches, 6' cheater bars, sledge hammers.... they all come in handy when working on a vehicle at one time or another.
Old Jan 18, 2006 | 04:24 PM
Matt RX8's Avatar
how is the $30 tool any different then the $4 tool?
Old Jan 18, 2006 | 04:46 PM
zaglo6204's Avatar
mine's better
hey coda-
i see that you live in savannah (& atlanta). im here in savannah too, & was unaware anyone else here was really 'interested' in their 8. i'll be changing pads sometime, not sure when, but i would love to have an expert at hand, but moreso to just meet up. if you're around, maybe we could talk about places to drive, etc. sometime! my e-mail is zaglo6204@mac.com, if that's easier for you.
Old Jan 18, 2006 | 05:41 PM
Section 8's Avatar
more info here.
Sweet. I'll have to pick one up. Thanks
tjohnmeyer
Sep 28, 2017 05:03 PM
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
