handbrake inside cover cracked!
Old Jan 12, 2006 | 01:24 PM
ranny3's Avatar
handbrake inside (tab) cover cracked!
Hi
The black bottom cover around the handbrake - the one that hides the mechanics of the handbrake cracked. Now i can see what's under the handbrake (i can see the color of the car, some metal gears, etc).... I don't know how it cracked - but should this be covered by warranty - it seems to be really flimsy if it cracked on its own?
thanks
Old Jan 13, 2006 | 10:28 AM
fray's Avatar
Fairly common problem, it's replaced under warranty. A number of the folks that get together regularly in MN have had the problem. (I've had mine replaced once.. no signs of cracking since then.)
Old Jan 13, 2006 | 10:54 AM
ranny3's Avatar
hi Post #2, that is exactly what happened!!!!
yes the tab broke off i don't even know how i just noticed one day it was broken.
The dealer said its not covered under warranty, and it will cost 200$ (CAD) to replace it
Any help/suggestions? This should be covered IMO
Old Jan 13, 2006 | 10:55 AM
ranny3's Avatar
Hi
Post #3, how did you get it to be covered? Did you have to tell the dealer anything specific?
thanks!
Old Jan 13, 2006 | 11:24 AM
Glyphon's Avatar
脾臓が痛みました
can you try a different dealer?
Old Jan 13, 2006 | 11:26 AM
fray's Avatar
All of the folks I know of (including myself), simply went into the dealer and said "The boot on the e-brake is cracked/missing." Quick response was "ok, we'll order the part and call you when it's in."
Which is exactly what they did, no cost. (FYI, the boot is part of the e-brake assembly so they have to replace the WHOLE thing, not just the boot.)
Old Jan 13, 2006 | 12:39 PM
ranny3's Avatar
damn... the dealer i go to is usually good about stuff (they were only ones to replace brakes because of squealing)... i guess i have to call around other dealers.
Old Jan 13, 2006 | 12:43 PM
Asmoran's Avatar
If you really like them, go back and talk to them about it. Try to talk to a different person. Say that other dealerships are repairing it under warranty, and see if you can talk them into it.
Old Jan 13, 2006 | 01:30 PM
ranny3's Avatar
thanks for you answers.... good to know rx8club is out there for support!
Old Jan 31, 2006 | 01:29 PM
RetroRotor79's Avatar
Had mine replaced under warranty last summer but it broke again on the first day of sub 32 degree weather. So mine has broken twice during normal use. I'm going in for an oil change and will mention it, but apparently the replacement won't solve the problem.
Old Jan 31, 2006 | 01:48 PM
whosyourbaba's Avatar
Mine broke twice, always in the winter. I'm going back to fix it when winter is over.
Jst4fun
Apr 17, 2021 07:43 AM
Oct 3, 2015 09:51 AM
SimonT182
Oct 2, 2015 10:33 AM
GK1707
Sep 27, 2015 07:33 PM
