Have any late model 2005s Flooded?
Old Jan 12, 2006 | 01:15 PM
msrecant's Avatar
Hubble has been saved!
Before your flame me, this is not just another flooding thread.
The 12/1/2005 "Engine cranks no start" TSB says that all three changes (battery, starter and plugs) were incorporated in production cars starting 3/22/2005. Dealerships imply that this "fixes" the flooding problem. However, Mazda still maintains that short trips should be avoided. So I am asking the following:
If your car's build date (see sticker on driver's door jamb) is 4/2005 or later please post here if your car has ever flooded (MT or AT). Please note your build date in your post and quick statement about how you got the car restarted.
Thank you!
Old Jan 12, 2006 | 01:19 PM
Papapump51's Avatar
ROSSIFUMI GAMBATTE !!
5/2005 here, no flooding, had battery changed under warrenty though low amps, they put in a higher cranking battery , after that all runs great but never flooded...i still do not do shorts trips with no warm up, or I rev to 5k then shut off as the dealer and rx8.com has explained to do.
Old Jan 13, 2006 | 12:37 AM
AQA101's Avatar
Stainless
11/2005, no flood and the environmental conditions here would currently be perfect (I experienced a flood with my previous car, 05/2003 MT).
Old Jan 13, 2006 | 02:36 AM
Krankor's Avatar
Klingon Grammarian
Um, remind me again how I find out my car's build date...?
Old Jan 13, 2006 | 06:30 AM
Go48's Avatar
Sticker on the drivers side door jamb.
Old Jan 13, 2006 | 09:23 AM
msrecant's Avatar
A word is worth 1/1000 pictures.
Attached Thumbnails Have any late model 2005s Flooded?-img_3885_edited.jpg   Have any late model 2005s Flooded?-img_3884_edited.jpg
Old Jan 13, 2006 | 11:29 AM
Dagious's Avatar
Motor City Madman
11/05 no flooding problems. Have done a few start, move and shut off's with no problem.
(Now that I've said that....)
Old Jan 13, 2006 | 02:12 PM
Krankor's Avatar
Klingon Grammarian
Thanks large, guys. Turns out I don't qualify for this thread.
(but I've still never flooded)
Old Jan 13, 2006 | 04:27 PM
07/05 - no flooding issues.
Had a few times where I had to crank the key a little longer to get it to start though...Anyone think I might need a new battery??
NEVER any short trips, I always let it warm before shutting down.
Old Jan 13, 2006 | 06:32 PM
Section 8's Avatar
I'd have to check my build date, but we bought in 11/05, no flooding issues to date. Deer issues now..that's another story
Old Jan 14, 2006 | 03:20 AM
YT1300's Avatar
Turning and burning
07.2005, I think. No floods.
Old Jan 14, 2006 | 07:30 AM
mjcampb's Avatar
Well, I've got an early '05 (11/04 build) and never flooded with multiple in/out of garage moves and other short trips.
Old Jan 14, 2006 | 08:52 AM
RoXanneBlack8's Avatar
stop flooding ur engines
even after the revisions we do with the battery, plugs, and starter, the cars can still flood. a 2006 will flood if you shut it off cold. its the design of the engines and u can only reduce the chance but not solve it. revision or not, they can still flood. let it warm up all the way and youll be fine!
Old Jan 14, 2006 | 09:11 AM
Marc_H's Avatar
04/2005 Build Date
Manual Transmission
No Floods. The only time I had a cold shutdown was early on when I stalled it. I needed to relearn how to drive a stick after 10 years driving an automatic. It started up again with no problem.
Old Jan 14, 2006 | 09:22 AM
Rotary78's Avatar
ZOOM ZOOM ZOOM
I've got an '05 M/T 8 and i haven't had any problems with the car flooding, or hard starts... I even accidently shut the car off in the middle of winter, when it was snowing out and it was freezing cold, next morning it started fine.
Old Jan 15, 2006 | 03:15 PM
Oranje's Avatar
JM1FE
October 2003 Build
Original Battery, Starter, Plugs
6-speed MT
22,053 miles
Never Flooded
Never had any short move shut offs
Currently hiebernating for the winter
Cheers,
Oranje
Old Jan 17, 2006 | 06:25 PM
lshu's Avatar
Driving makes me :)
11/04 build date, no floods but a few times i did need to crank a little longer than usual to get the car started... and I have had a few cold short-distance shutoffs
Old Jan 17, 2006 | 07:54 PM
PIGBAIT's Avatar
July '05 build date.
No flooding issues.
Old Jan 20, 2006 | 09:54 AM
msrecant's Avatar
This post has been active a week and not one report of a 2005 build after 3/22/2005 being flooded. Definitely a good sign. Unfortunately you can't prove a negative result.
Old Jan 31, 2006 | 10:30 AM
msrecant's Avatar
FYI - It has been over two weeks. The only report to date of a flooded late model '05 came on another forum: wife backed it out of the garage and turned it off. While it did not immediately start the next day, it ultimately did start on its own but he ended up with a CEL so he had to go to the dealer anyway.
Old Jan 31, 2006 | 12:13 PM
05whiterx8's Avatar
Director of Service
7/04 build date, no problems whatsoever
Old Jan 31, 2006 | 01:12 PM
griffe's Avatar
Were there any instances where FD's flooded? or is this something that is inherent to the Renesis?
Old Jan 31, 2006 | 01:14 PM
Raptor2k's Avatar
Club Marbles Member
^good question, I've never seen 'rx7' and 'flooding' go together
Old Jan 31, 2006 | 02:09 PM
NoTears316's Avatar
Shock and Awe
I think this whole flooding thing is like a UFO sighting. I have an 8 with an Aug 03 build date, purchased it 2 weeks after the build date, and have never come close to flooding the thing.
Old Feb 1, 2006 | 07:20 AM
msrecant's Avatar
FD owners are very familiar with flooding but, like RX-8s, not every FD owner flooded. The issue is a Mazda rotary one, not just a RENESIS issue. I believe it is a more noticable issue with RX-8s because there are a lot more RX-8s sold than FDs and I believe the average RX-8 driver is less technical (less likely to take the steps necessary to avoid flooding).
