Attempt at making a TPMS fooler
Old Jan 10, 2006 | 11:49 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Anyone care to guess what this is that I am making? Care to wager if it will work or not? I will do a DIY if it does work.
Attached Thumbnails Attempt at making a TPMS fooler-diy-tpms-fooler-002.jpg   Attempt at making a TPMS fooler-diy-tpms-fooler-003.jpg   Attempt at making a TPMS fooler-diy-tpms-fooler-005.jpg   Attempt at making a TPMS fooler-diy-tpms-fooler-007.jpg   Attempt at making a TPMS fooler-diy-tpms-fooler-009.jpg
Old Jan 11, 2006 | 02:54 AM
EfiniRX8's Avatar
I'm guessing you got new wheels and didn't want to put the TPMS in them for the reason of balance and etc.. So you've made this tube in which you will fill up with air to simulate the pressure in your tires in hope of tricking the computer in to thinking your sensors are in. (My bet is it will work ) hope i'm right
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I'm guessing you making a pipe that will hold 32psi in order to fool the TPMS system.
Old Jan 11, 2006 | 02:56 AM
Damn you beat me to it efrini....by only a second.
Old Jan 11, 2006 | 07:01 AM
expo1's Avatar
He's as bad as Can
Well looking over some older threads like this https://www.rx8club.com/series-i-tech-garage-22/disabling-tpms-18784/ I am lead to believe the TPMS system gathers more than just .PSI data. So filling that tube to 32 lbs will not fool the TPMS system. BUT adding air to that tube might be enough to turn the TPMS sensors on and you could then scan what radio frequency they transmit on? That information would be needed to make a TPMS ‘fooler’
Old Jan 11, 2006 | 07:10 AM
LiL BenNy's Avatar
Bubblicious? DEF.
is it a bong?
Old Jan 11, 2006 | 07:17 AM
Critters's Avatar
some sort of sex aid?
Old Jan 11, 2006 | 07:57 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Originally Posted by expo1
Well looking over some older threads like this https://www.rx8club.com/showthread.php?t=18784 I am lead to believe the TPMS system gathers more than just .PSI data. So filling that tube to 32 lbs will not fool the TPMS system. BUT adding air to that tube might be enough to turn the TPMS sensors on and you could then scan what radio frequency they transmit on? That information would be needed to make a TPMS ‘fooler’
While the TPMS sensors transmit or can transmit more than just pressure data, I was under the impression that the RX8 TPMS system just uses the pressure info. We will see though. Unfortunately, I dont have a RF scanner. Currently chasing down leaks. PITA.
Critters,
Sex aid? What are you into?
Old Jan 11, 2006 | 08:13 AM
Asmoran's Avatar
With a name like critters, I really don't think we want to know.......
Old Jan 12, 2006 | 08:00 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Well, the house lost. (assuming I reset the system correctly) I finally got all the leaks sealed, but the blinky light came back on. What that means is that the sensors are triggered by the centrifugal force of spinning or that they send that signal to the TPMS receiver. Next would be to dig in to the sensor to see if you could fool it to send the correct signal.
I will say this. I think that the TMPS responds differently to advancing number of drive cycles. When I first replaced the wheels, the light would come on after, say, 20 min. Eventually it would beep at me and come on sooner. The very last time before trying my fooler the light came on immediately. Dont know what that means.
Old Jan 12, 2006 | 08:11 AM
expo1's Avatar
He's as bad as Can
Yes, to save battery life they are activated by tire rotation. This is the second year of my use of winter tires without TPMS and yes at first it takes 15-20 minutes for the warning light to come on. The longer you ‘ignore’ this light the faster the light will come on, I just cover the light and never see it.
Old Jan 12, 2006 | 09:24 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I am going out an buying some flat black (non-glossy) stickers right now.
Any more ideas on this would be appretiated. After I extract my sensors, I would be happy to donate them to the cause as a test bed.
Could a mod please retitle this thread to better indicate what it is? Thank you!
Old Jan 12, 2006 | 09:29 AM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-cover-tpms-light-47499/ Worked for me.
Before you open them up finding someone that could try and get the RF would be better I think.
Old Jan 12, 2006 | 01:00 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
But if the rotation of the wheels turns them on, wouldn't it just be better to scan a stock car in motion or just resently stopped after a short drive? If mine arnt on, you wont get a signal? BTW do you have a scanner?
Old Jan 12, 2006 | 01:14 PM
expo1's Avatar
He's as bad as Can
That type of work is beyond me, but if you had an exercise bike around you could attach one TPMS to the wheel while someone pedals? Putting the TPMS onto something that spins around shouldn’t be too hard.
Old Jan 12, 2006 | 02:08 PM
Why didn't you just epoxy them to the inside of the rim before you mounted the tire. I'm sure that would work.
Old Jan 12, 2006 | 03:05 PM
r0tor's Avatar
the tire rotation pushed the battery against the contacts in to give it power... so no centrifigal force, no battery touching the contacts and no signal (as you have just found out)
Old Jan 12, 2006 | 03:24 PM
That seems like a simple fix, just wedge something in there.
Old Jan 12, 2006 | 03:36 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I dont want them on my rims. They are not worthy. But I also dont want that damned blinky light either.
Old Jan 12, 2006 | 03:37 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
So they have to be wedged and then under pressure? Do you have more info? circuit discriptions? rf frequencies?
Old Jan 13, 2006 | 10:23 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Originally Posted by Cool-Blue-Dad
Actually, this sounds like a good reason to go ahead and open of the sensors. Find the battery and contacts and wire it up to be always on. You might be just that close to kludging around the problem.
If I get around to dremeling them out of there this weekend, I will do exactly as you say. Basically start a careful archeological dig into one of the sensors. They are expoxy filled and sealed (There is a name for this but I am blanking on it right now) I just have to carefully remove that sealant (which is very difficult. it tried it once on another unrelated system some years ago and ruined the circuit board.) I will post pics. Your help is much appretiated.
Thanks Zoom, for the thread name change!
Old Jan 13, 2006 | 12:14 PM
Boxcar's Avatar
Round round round we go
Good idea and good luck but hope to god you never get stoped driving into the airport. I can just imagine trying to explain what that is to the cops.
Old Feb 19, 2006 | 06:39 PM
RX-Nut's Avatar
8 the HARD way.
any luck with this?
Old Feb 19, 2006 | 06:42 PM
Im_DANomite's Avatar
I love GOOOLD
it won't work, i've already tried this. the TPMS sensors also send out wheel speed information. if the car is in motion and doesn't detect wheels speed from the sensors, it'll still set off the light.
