Is there any bad effect to the fuel system??
Old Jan 9, 2006 | 09:39 PM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
I'm very curious here. Since i had the hard start problem (before the car stalls), while cranking the engine i step the acc pedal about 25% (not flooring it). I did start the car but it will cause the fuel injector to malfunction, am i right?? All i know when you fully floor the acc pedal, this will cut the fuel (a step of deflooding process).
Gimme some light please
Old Jan 10, 2006 | 11:53 AM
caribbean_spice_boy_73's Avatar
Work in Progress
use search
Old Jan 10, 2006 | 12:43 PM
zoom44's Avatar
leave your foot completly off the pedal when starting UNLESS you are trying to de-flood- then holding the pedal all the way down will shut off the injectors so that the engine can crank all the fuel out.
Old Jan 11, 2006 | 06:29 PM
RX8 Brunei's Avatar
Rotary Lover
Originally Posted by caribbean_spice_boy_73
use search
I've searched in the forum, even by google search engine but i couldn't find any. And you're not helping me here. Thanks for nothing.
Old Jan 11, 2006 | 06:31 PM
RX8 Brunei's Avatar
Rotary Lover
Thank you bro. What if i'm playing the pedal back and forth continously while cranking the engine?
Old Jan 11, 2006 | 06:36 PM
RX8 Brunei's Avatar
Rotary Lover
Are these "rotor housing" fuel injectors fouled/malfunction?? I don't see both injectors clogged.
Attached Thumbnails Is there any bad effect to the fuel system??-image793.jpg   Is there any bad effect to the fuel system??-image796.jpg
Old Jan 11, 2006 | 06:39 PM
RX8 Brunei's Avatar
Rotary Lover
another pic
Attached Thumbnails Is there any bad effect to the fuel system??-image791a.jpg
Old Jan 11, 2006 | 06:44 PM
RX8 Brunei's Avatar
Rotary Lover
this "intake manifold" injector is normal i think...
Attached Thumbnails Is there any bad effect to the fuel system??-image800.jpg
Old Jan 12, 2006 | 09:54 AM
zoom44's Avatar
dont do it
Old Jan 12, 2006 | 06:23 PM
RX8 Brunei's Avatar
Rotary Lover
dont do it
frankly, i did it everytime (when hard start cranking) . so i end up with fouled injector eh?
drebbrnator
Dec 27, 2018 07:02 PM
Nisaja
51
Sep 1, 2015 04:29 AM
ShadowGryphon
Aug 23, 2015 02:46 PM
steve11711
Aug 22, 2015 11:11 AM
