what is this light indicator mean??
Old Jan 9, 2006 | 12:44 PM
mdroz8's Avatar
hey all, sorry for a question that i could easily find in my manual, but i lost my manual!!
this indicator is orange, shaped kinda like a raindrop except the bottom is straight and jaggedy across, and it has an exclamation mark right in the middle of it. it's located right next to the gas indicator. my car beeped at me 3 times and displayed this. has been intermittent for the last couple days.
please tell me what this is so i can take the appropriate action! thx!
Old Jan 9, 2006 | 12:50 PM
zoom44's Avatar
tpms- your tires need air
RotoRocket's Avatar
Freely Radical
Edit - Zoom beat me to it. You're fast Zoom!
It's your tire pressure monitoring system (TPMS) warning you that your tire pressure is not correct.
It's probably close, but when you get your tires warmed up after the first initial miles, they are probably reading higher, and triggering your TPMS.
Here you go:
Old Jan 9, 2006 | 12:58 PM
RotoRocket's Avatar
Freely Radical
Here you go:
I just noticed that whoever has the above car (in the photo), does not have Dynamic Stability Control.
Old Jan 9, 2006 | 01:31 PM
StewC625's Avatar
Insanely Yellow
Note:
In colder weather, your tires lose pressure relative to the pressure in warmer weather - i.e. the same tire at 32 PSI at 70 degrees will read about 23 to 26 PSI at 20 degrees.
Bottom line, you have a tire or more that needs some attention - go check your tire pressures when they are cold (no more driving than 1 mile after having cooled several hours since the last drive), and correct to 32 PSI while still cold.
That will solve the issue.
Old Jan 9, 2006 | 01:36 PM
blue flash's Avatar
I Think The Shift Lite Is For Automatics
Old Jan 9, 2006 | 01:38 PM
Gomez's Avatar
Shifty Bastard.
Originally Posted by djseto
Green arrow below the TPMS..is that a shift light?????
Yeah...I've never seen that on an RX-8 dash before, although I can't say I've looked for it. Is this a photo of a pre-production instrument cluster??
Old Jan 9, 2006 | 01:39 PM
Gomez's Avatar
Shifty Bastard.
Nope....check the indicated redline.
Old Jan 9, 2006 | 01:42 PM
RotoRocket's Avatar
Freely Radical
I found the photo on another thread here.
Maybe it is pre-production...
Old Jan 9, 2006 | 01:44 PM
blue flash's Avatar
in this picture the cars is not running .he just turn the ignition on to show all the lights.
Old Jan 9, 2006 | 01:48 PM
Socr8tes's Avatar
Indicated redline, not RPM...
Old Jan 9, 2006 | 02:02 PM
iKenndac's Avatar
Isn't a shift light the caps lock light on your keyboard? Maybe that '8 has the optional keyboard attached, for entering stuff into the Satnav?
Old Jan 9, 2006 | 02:09 PM
Gomez's Avatar
Shifty Bastard.
Real sense of humour, you Poms!!!
Old Jan 9, 2006 | 02:11 PM
Gomez's Avatar
Shifty Bastard.
Which country did the poster come from?? I'm starting to think this cluster is region specific.
Old Jan 9, 2006 | 02:26 PM
Gomez's Avatar
Shifty Bastard.
I found another odd cluster with this light......my door open/seat belt indicators ain't up there either.
Attached Thumbnails what is this light indicator mean??-instrument-cluster.jpg
Old Jan 9, 2006 | 02:39 PM
iKenndac's Avatar
The cluster is definitely regional - my 8's cluster is the other way round - the fuel gauge and temp. gauge is on the right, and the oil pressure and trip is on the left. I'm pretty certain I hae seatbelt and door open lights, too. No shift light, though.
Old Jan 9, 2006 | 02:51 PM
blue flash's Avatar
i thought when i test drove an automatic it had the shift lifts.99%sure
AndyV's Avatar
Lurker
Originally Posted by mdroz8
...but i lost my manual!! ...
http://www.mazdausa.com/MusaWeb/pdf/...004_owners.pdf
Found this while logged in as an owner on the Mazda site.
Old Jan 9, 2006 | 03:19 PM
Gomez's Avatar
Shifty Bastard.
I know bugger all about automatics....never seen one, no-one in Australia buys them. However, I know they have a 7500rpm redline and the pics posted in this thread show an 8500 red band and a 9000rpm redline.
These clusters are from a manual RX-8.
Old Jan 9, 2006 | 03:23 PM
iKenndac's Avatar
Maybe it's a visual version of the red band 'beeeeep' you hear when up at 8500rpm?
Makes sense... an up arrow for upshifting, green to let you know it's the right time to shift, etc.
Old Jan 9, 2006 | 03:26 PM
Gomez's Avatar
Shifty Bastard.
Yeah.....for which market?? This is a LHD cluster.....so it ain't Japanese.
Old Jan 9, 2006 | 03:29 PM
iKenndac's Avatar
Not sure - maybe a track version of the 8, or a feature that was pulled right at the last second (i.e., it was too distracting)?
Old Jan 9, 2006 | 03:35 PM
Gomez's Avatar
Shifty Bastard.
Maybe your mates over the channel have it?
Old Jan 9, 2006 | 03:44 PM
deamicls's Avatar
You guys are all wrong. I think that it's the "low gas" light. You can see the gas gauge almost pointing to E.
