throttle position sensor
Old Jan 8, 2006 | 10:18 AM
joon's Avatar
strictly rotory
Unhappy throttle position sensor
hey guys put the car on the dyno yesturday andwe noticed the tps lights went on after 3 dyno runs any suggestions as to why this came on.its a garret 35r turbo with bairings so that it will spool faster. also the engine light is on.
Old Jan 8, 2006 | 12:30 PM
zoomzoom_8's Avatar
tps light is not throttle position, i think the light ya had was the traction light. it came on because you did not disconnect the two speed sensors to the real wheel thereofre with the back wheels spinning and the front ones not, the 8 thought you were out of control, cut the power and gave ya a faulty dyno reading.
zoomzoom_8's Avatar
tps - also tire pressure (what did the light look like?)
Old Jan 8, 2006 | 06:35 PM
joon's Avatar
strictly rotory
hey zoomzoom 8 i just went by what my mechanic said i'll have to get back to you, if its tps that should be tire pressure sensor cause i dont have the valve stems on the after market rims.
Old Jan 8, 2006 | 07:32 PM
zoomzoom_8's Avatar
the tps light for tire pressure looks like a little ! sign. if it was the traction control, it would be a little car swerving. That is when power is actually cut, but with interceptor i do not know if that will still cut the power, the int is so new to me, first night with it.
Old Jan 8, 2006 | 09:31 PM
joon's Avatar
strictly rotory
well when it was on the dyno we did turn off the dcs which shows the car swerving symbol and the little ! sign was on because of my after market rims without the tire pressure senser. it was on the laptop that mentioned the throttle senser when connected to the interceptor-x. will talk to scott tomarrow and see
92trbolzr
May 18, 2025 09:04 AM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
drlubell
Sep 26, 2015 11:58 PM
