dynamat/alternitaives?
Old Jan 7, 2006 | 09:41 PM
LiL BenNy's Avatar
Bubblicious? DEF.
so with my setup ive been recently experiencing a lot of rattle and its time to dynamat my trunk.. now the question is would the best one to use be dynamat extreme? or other brands better? any recomendations? how many sq ft would be enough and should i dynamat in the cabin in adition to the trunk? lastly when i do dynamat it what part of the pass through would i dynamat cause i notice alot of the rattling stops when the passthrough is taken off
Old Jan 7, 2006 | 10:00 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Dynamat extreme can't not be removed- just something to think about.
I used about 100 sq feet to do the entire car.
You can only dynamat metal- locate the rattle from the pass through and work from there.
Old Jan 7, 2006 | 10:01 PM
Astral's Avatar
Purveyor of fine bass
dynamat extreme == TOO EXPENSIVE.
http://www.raamaudio.com/ <-- RAAMmat BXT, best bang for the buck, IMO. it's one of the easiest to install (sticks really well, don't really need a roller, don't need a heatgun). plus the guy that sells it (Rick) is SUPER helpful.
Don't get Fatmat! Too many problems with it.
Also decent is eDead V1.SE, but it may not stick as well.
Second Skin Damplifier is another great product, http://www.secondskinaudio.com/cgi-b....cgi?pg=1&p=pr but it's slightly harder to install than RAAMmat BXT, but I think it has better temperature resistance (if you're in hot as hell somewhere, may survive longer than BXT). i also recommend Damplifier.
I've personally used RAAMmat BXT and it was easy to apply and great. my roommate did the rear deck of his STI with it and it worked great. i did the doors with it and it was nice, but I haven't done the trunk yet.
As far as deadening the trunk on the RX-8, I am not sure.. maybe 10 sq ft is enough? Dunno. I would also be interested in hearing about the strategies for deadening the RX-8 trunk.
Old Jan 7, 2006 | 11:07 PM
StealthTL's Avatar
Metatron
Exclamation 100 sq ft.....
That stuff works by dampening, i.e. being heavy!
The average "mat" material is around 1/2lb per square foot!
...but I guess if your aim is to put 12" speakers in the trunk, what's another 50lbs?
S
Old Jan 7, 2006 | 11:41 PM
Yea, my stuff was 44lbs. I used fatmat......
Old Jan 8, 2006 | 11:40 AM
LiL BenNy's Avatar
Bubblicious? DEF.
thanks for all the replies! anyone else used RAAMmat BXT or heard of it?
Old Jan 8, 2006 | 11:49 AM
LiL BenNy's Avatar
Bubblicious? DEF.
astral... did you also use the ensolite? if so how much did you get?
Old Jan 8, 2006 | 07:24 PM
Astral's Avatar
i bought 4 yards of ensolite, as i figured that should cover two doors and the rear deck and still have enough left over for random things. but i haven't used any yet, because i didn't have enough time before the weather got cold to do an all-out thorough install. will probably do trunk & rear deck, using BXT and ensolite, this spring.
rick also recommends the adhesive that he sells (below the ensolite on that page), as he says it bonds the best and is the safest for automotive use (of the ones he found).
i say you can try with 2 yards of ensolite & 1 can of adhesive and see if you need more. i was splitting mine w/ my roommate, so i ordered enough for my rx-8 and his sti.
Old Jan 8, 2006 | 08:35 PM
LiL BenNy's Avatar
Bubblicious? DEF.
the adhesive is for the ensolite to bond to thebxt or the bxt to bond to the car? also can you give me their email? i know its on the site but when i click it my netscape brings up this whole thing to log in and i cant view what their email was... thanks a lot astral for all your help!
Old Jan 8, 2006 | 10:14 PM
Astral's Avatar
the adhesive bonds ensolite to any surfaces, such as the bxt or sheet metal or plastic. the bxt has adhesive built in to the back.
rick -at - raamaudio.com
Old Jan 18, 2006 | 11:29 PM
ElPaco13's Avatar
Bite my shinny metal...
Damn right. I went to a local trim and interior and got the padding that goes under the interior carpeting. I think the guy kept calling it juke mat. It was a fraction of the cost... $21 for a 9 foot by 38 inch piece. I have an old Cherokee that I drive in the winter and I just put in a small piece behind a 12" sub I have. I couldn't belive the difference it made. It helped to stop the whole car from rattling!
Old Jan 18, 2006 | 11:43 PM
Astral's Avatar
It's "Carpet Jute". One thing though with Jute is that those open-cell foams can "absorb moisture, leading to mildew and nasty odors." You should look for closed-cell foam, such as Ensolite MLC sheeting, for the most automotive-environment-friendly solution.
