View Full Version : How to deal with boost creep?
Hybrid-RX8
01-03-2006, 01:47 AM
I am currently running the Greddy turbo kit..
I am often enough dealing with boost creep and boost spiking..........so on the safe side I would like to install a external wastegate to help remedy the problem....
What would be the ideal size? I have access to a Tial 46 with a .5 bar spring.
I aware of all the articles stating a smaller wastegate is better matched a smaller turbo running higher boost..and a larger wastegate is matched better with a larger turbo running lower boost.....I have also read that that exhaust gas output on the rotary does change alot of these rules... I notice the RX7 guys are typically running 46mm.
Any input?
rkostolni
01-03-2006, 12:35 PM
You could always port out your internal wastegate.
MazsportScott
01-03-2006, 12:44 PM
What boost controller are you running?
Hybrid-RX8
01-03-2006, 01:48 PM
I am using a Profec B Spec II but had problems before the boost controller was placed in. The problems became more significant when my mid pipe was gutted as well.
Hey Scott, I haven't heard back from you in regards to the Modified Mag situation. I look forward to hearing from you soon.
zoom44
01-03-2006, 02:04 PM
leak?
Hybrid-RX8
01-04-2006, 04:00 PM
Checked..no leaks
SSR Engineering
01-04-2006, 04:19 PM
Any input?
The reason i'd go with the Tial 46 is because of the components it is made with. It is a nickel based compound for the housing and an inconel valve which can withstand temperatures of 2000+ Farenheit, which makes it ideal for a rotary. Where as the 44 uses a stainless valve/nickel housing and a vband assembly, the 38 uses a stainless valve and housing (and isn't big enough for your application).
