Lock & Load
08-01-2003, 01:40 AM
Any one else notice the indentation in the boot on the right hand side on the inside this helps in lowering your boot and then closing it properly just watch your fingers .
View Full Version : CLOSING BOOT procedure Lock & Load 08-01-2003, 01:40 AM Any one else notice the indentation in the boot on the right hand side on the inside this helps in lowering your boot and then closing it properly just watch your fingers . Titanium RX-8 08-02-2003, 08:04 AM Loack and Load that was a gem. No more fingerprint smudges on the bootlid when closing;) Has anyone else removed the spare tire. I took mine out today as its the only way our three wheeler pram will fit in the boot. B-Nez 08-04-2003, 09:57 AM I've been using it sharply pull the boot closed without touching the decklid, also. You don't think that is bad for the hydraulic arms, do you? Doctorr 08-04-2003, 11:12 AM Thanks L&L, I would probably never have seen that hand-hole if you hadn't mentioned it! You have to look UP! I had been pulling the lid by it's 'catch', and getting all greasy! . . . doc |
