Flooding when its over 40 degrees?
Hi, I'm looking to purchase one of these beasts, but have read about the flooding issue.
Is this a localized problem to cold areas? I live where it does not get below 40 degrees F, does this occur at temperatures above 40?
Temp...while I "think" might...MIGHT increase the likelihood (if for no other reason as it takes longer to heat up)...flooding, it is an overblown issue. Sure...it can happen, but it's a rare thing if you simply do not turn off the engine until it's warmed up.
So...no moving your 8 from garage to driveway while the engine is cold and turning it off. I've owned my 8 for about a year now and I have never had an issue.
But...it can happen, like any engine but with the rotary (while cold) it's a little more susceptible.
So, turn the key...wait till it lights up your dash (seems to start the engine better), and DON'T turn it off cold and you wont' have a problem.
Again...there are stories of it happening, but (I was a newb once too) a problem I worried about for a long time turned out to be nothing but driver/owner error.
Golden rule #1 for the rotary, Don't turn it off cold but remember there are ways to avoid it or be saved from it also.
Rule #2…at every or every other fill up, check the oil. Of course if you run her hard she will eat a bit more oil but its part of the design of the engine not a problem.
I live in ny and at times we've had 10 degree F- weather a few weeks ago. I'm completely aware that if I inadvertantly shut it down without properly warming it up, I'd be screwed. But thankfully due to this second nature of such awareness that I have for the car, I never flooded my engine (knock on wood)
Danield97
Oct 10, 2015 05:58 PM
duworm
Oct 1, 2015 04:57 PM
