Stock Injector Specs?
Old Dec 27, 2005 | 12:27 PM
Kags1969's Avatar
I am wondering what the stock injector specs are? High Ohm or Low Ohm and what flow rate at what psi... anybody have an idea?
Thanks,
Chris
Old Dec 28, 2005 | 03:28 PM
Kags1969's Avatar
No one know?
Old Jan 8, 2006 | 07:07 PM
MadDog's Avatar
Consiglieri
^those are for the high-power Renesis. Its different on the std-power.
Old Jan 12, 2006 | 07:30 PM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
Hey kags, I got those specs you asked for. Sorry to be a couple days behind. They are:
P1 276-312 cc's/min (red)
P2 356-404 cc's/min (yellow)
S 356-404 cc's/min (yellow)
resistance on all injectors should be approximately 13.8 Ohms at 68 degrees F.
CRH
Correct me if i'm wrong. I believe there are 4 units of intake manifold injectors (yellow) & 2 units of rotor housing injectors (red) . Altogether 6 injectors in high-power Renesis.
Old Jan 13, 2006 | 12:31 PM
MadDog's Avatar
Consiglieri
^yes. P1's are direct injection. P2 and S are in the intake.
Old Jan 13, 2006 | 07:20 PM
RX8 Brunei's Avatar
Rotary Lover
Forgive me if my question is sound a bit stupid. When we start/crank the engine, does the fuel injected through all the injectors or just the direct injection? What about while the engine is idle? If there's any link that shows how the High-power Renesis works when starting/cranking , idling & revving .... that would help a lot.
Old Jan 13, 2006 | 07:33 PM
zoom44's Avatar
only primary 1 injectors fire at start up and while driving below 3750 rpm
Old Jan 13, 2006 | 09:15 PM
RX8 Brunei's Avatar
Rotary Lover
Thanx for the info.
Old Jan 13, 2006 | 09:48 PM
zoom44's Avatar
actually let me double check that- ill get back to you tomorrow or sunday
Old Jan 14, 2006 | 12:36 AM
RX8 Brunei's Avatar
Rotary Lover
Take your time. I suspect my direct injectors ain't working that's why i'm asking.
Old Jan 14, 2006 | 06:23 PM
MadDog's Avatar
Consiglieri
If they weren't working, you would not be able to drive it *at all*.
Old Jan 15, 2006 | 05:28 AM
RX8 Brunei's Avatar
Rotary Lover
That's right !! My 8's current problem is "hard start engine" & DTC P0171 "system too lean".
Old Jan 18, 2006 | 10:29 PM
RX8 Brunei's Avatar
Rotary Lover
Yo Zomm44!! Have you figured out the injectors yet?
Old Jan 18, 2006 | 10:55 PM
MazdaManiac's Avatar
As I stated in this thread:
"The RX-8 "hi-power" has 6 fuel injectors, 3 per rotor, that are designated primary, secondary and primary 2. The primary injectors are 290cc and the secondary and primary 2 injectors are 380cc.
These injectors are staged in various levels and configurations based on load and RPM, which is quite different from any piston engine.
The primary injectors are responsible for most of the fuel delivery at part throttle and completely for idle. They are usually run out to maximum output by 3500 RPM and WOT.
The secondary injectors are responsible for much of the fuel delivery under load beyond 4800 RPM, but are seldom driven beyond 60% of their capacity.
The primary 2 injectors are brought online around 6250 RPM and are not driven beyond 35% or so."
Old Jan 19, 2006 | 11:01 AM
zoom44's Avatar
i was actually going to look for jeff's post as its easier than searching thru the manual
Old Jan 22, 2006 | 11:35 PM
RX8 Brunei's Avatar
Rotary Lover
Thanks for the info MM.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
GK1707
Sep 27, 2015 07:33 PM
