How do you check for flash/ecu version>
Old Dec 22, 2005 | 11:31 AM
nedor's Avatar
I've search for flash / ecu in forum but I am not having much luck.
Please help.
Nedor
Old Dec 22, 2005 | 11:56 AM
lurch519's Avatar
www.evoperform.com
either take it to the dealer, or get the scanalyser by hymee, it will allow you to read the version number for the flash, as well as lots of other cool stuff
Old Dec 22, 2005 | 12:59 PM
zoom44's Avatar
or canscan by harrison
Old Dec 22, 2005 | 05:13 PM
onekwik7's Avatar
[QUOTE=nedor]I've search for flash / ecu in forum but I am not having much luck.
Please help.
Nedor[/QUOTE
I'm having the same problem. Let me kow if you find some info.
Old Dec 22, 2005 | 05:38 PM
zoom44's Avatar
what ar eyou looking for kwik7?
Old Dec 22, 2005 | 06:17 PM
onekwik7's Avatar
I want to know how many "flash" ecu software versions are out there and what the differences are also how to find out what version i have.
Old Dec 22, 2005 | 06:34 PM
tuj's Avatar
tuj
Most cars sold initially in the US had the K flash. There is no point to going back to the other flashes (unless your car is already modified with a piggyback ECU that depends on the existing design of the maps for a particular flash). Also, any service that is done on your car will probably eventually result in them reflashing it when the WDS detects it is out of date.
No one really knows exactly what the differences are, but there is speculation. Ultimately, its unimportant, as the current flash is the best, and each flash from K has been a subsequent improvement in driveability and power.
There is a test to verify the installation of the R flash, invovling rev'ing the car to 8k while in neutral and stopped. After 30 seconds, the ECU will reduce throttle to prevent excess heat build-up.
Old Dec 22, 2005 | 09:39 PM
onekwik7's Avatar
Thanks for the info. Is the R flash the latest version? Are these new flashes just to keep the emissions and cel in check with no regard to maximum power output? My car goes in on monday and I do'nt want to be dissapointed with the performance after they update the software. I rather live with the cel than to lose hp.
Old Dec 23, 2005 | 12:48 PM
skhmund's Avatar
THE BITCH IS DEAD
M chip upgrade
i herd bout this on other threads but would anyone have a clear definition of what it is and if it is free?
Old Dec 23, 2005 | 12:49 PM
zoom44's Avatar
you probably mean flash
Old Dec 23, 2005 | 01:18 PM
skhmund's Avatar
THE BITCH IS DEAD
im not really sure so yor prob right, but do i just go to a dealer to get it installed or do u thnk its alread installed? (05' silver 8)
Old Dec 23, 2005 | 01:35 PM
zoom44's Avatar
your rx-8 has the most current flash available. there isnt anythign newer to get or ask for
Old Dec 23, 2005 | 01:43 PM
onekwik7's Avatar
I thought the R flash was the latest vesion.
Old Dec 23, 2005 | 02:03 PM
zoom44's Avatar
it is if you ar e a2004 MY 6mt. if you are a 4at then your flash level after the recall is S.
if you have a 2005 you have different flash nomenclature but what matters is that everyone who needed recall work done and has had it done is on the most current flash available. if your car is involved with the recall and it hasnt been in yet then get it in and you will be on the most current. if you were not involved in the recall then you are on the most current.
read the sticky on tsbs and recalls. the link in the first post will take you to where you can find the recall and read it and see the table of flash numberings
Old Dec 23, 2005 | 06:35 PM
RX-8 flashes are the secret code of the rotary clan ...
Old Dec 23, 2005 | 06:57 PM
tuj's Avatar
tuj
When the cars came into the US, it was supposedly discovered that the cat life would be dramatically shortened if the cars were released to the public in the pre-K flash state. The K flash richened the mix considerably, which lowers temperatures in the cat, prolonging its life. Cat life will be federally mandated, and already is mandated at 100k miles in CA I believe (along with timing belts and all sorts of other stuff). After K, each flash sought to restore some of the power that was lost by running the car so rich. Some flashes, like P, are believed to only have changed other parameters, namely the RPM setting at which the AC compressor will disengage (now set to 5.5k instead of 7k I think).
BTW, no flash should ever generate a CEL. The R flash is considered the best, and we should be happy that Mazda is continuing to refine and improve the performance of our cars. Granted, they should have got the hp right in the first place.
Racing beat has experimented with retuning the ECU, but found little gains to be had in street applications. The R flash probably represents the best compromise of power, driveability, and emissions given the OEM equipment.
So yeah, get the R-flash, you won't be dissapointed.
Old Dec 23, 2005 | 07:01 PM
zoom44's Avatar
merged 2 threads talking about the same thing. re read in case you misses something
Old Dec 23, 2005 | 07:41 PM
moRotorMotor's Avatar
Rotary eXperimental-8
So I had my gas tank and front suspension recall done already, but the work order does not state that the car have the latest flash. What gives? Do I have to complain in order for the tech to flash my car to R?
Old Dec 23, 2005 | 07:45 PM
zoom44's Avatar
does it say " performed work as per 3305G" or some such?
Old Dec 23, 2005 | 07:57 PM
Yes it does. It is listed twice. One for the fuel tank recall and the second time for the front lower arm ball joint. That is it.
Old Dec 23, 2005 | 08:00 PM
and people don't understand why the "Racing Beat Arguement" thread exists, though I'm sure you didn't intentionally mis-state yourself ...
Correction, there is a good amount of power in the PCM to be found when combined with specific aftermarket parts, I'm not fully informed as to what RB is actually doing or not doing though
Old Dec 23, 2005 | 08:06 PM
zoom44's Avatar
really? so you think Racing Beat isnt pursuing it? ive got news for you- i hope you have a subscription to RXTuner
initial findings can be corrected upon furthur scrutiny
Old Dec 23, 2005 | 08:07 PM
zoom44's Avatar
well then you are on the current flash
Old Dec 23, 2005 | 08:36 PM
thanks, I was going off old info then it had been reported that way previously
Old Dec 23, 2005 | 08:37 PM
zoom44's Avatar
tuj was going off old info also. There will be new info in RXTuner
