Transmission Leak
Old Dec 21, 2005 | 10:52 AM
Willie27's Avatar
Transmission Leak
I just got my 2004 RX-8 about 3 month ago. Its a MT, and has 28K miles. Now I've noticed some leaking near the transmission. Figured I would just change the Tranny fluid while I took a look at it. Looks like it is leaking around a sensor on the transmission. Does anyone know what this sensor is? Is it Neutral Switch Sensor, Back Up Light Sensor, Transmission Fluid Temp sensor? The sensor is screwed in on the passanger side of the transmission, I will try to take pictures of it this weekend.
Has anyone else had this problem?
Old Dec 21, 2005 | 10:55 AM
Tigster's Avatar
RX8 ADDICTED!!!
I would just take it to the dealer and have them fix it. The car has a warranty, and if you want to put in a redline or royal purple just have the dealer do it.
Old Dec 21, 2005 | 11:22 AM
Go48's Avatar
Neutral switch on the drivers side, backup light switch on the passenger side. Have the dealer replace or repair like Tig says.
Old Dec 21, 2005 | 07:35 PM
Willie27's Avatar
Is this a common problem? Have you heard of anyone having a leak out of the backup light switch in the transmission? This seems unusual as my car only has 28K miles.
Old Dec 21, 2005 | 07:39 PM
beachdog's Avatar
It's a used car. You have no idea where its been. Maybe the original owner was obsessive compulsive and repeatedly tightened and loosened the switch.
Just bring it in and don't worry.
Old Dec 22, 2005 | 12:52 AM
Gomez's Avatar
Shifty Bastard.
The backup light switch is close to the exhaust and is subject to inspection during the 3305G Thermal Damage recall. Check to see if this recall has been carried out.
Old Dec 26, 2005 | 11:26 PM
Willie27's Avatar
Thanks guys for the advice. I will be taking it in to the dealer to check it out. Appreciate all your help.
Old Dec 27, 2005 | 07:28 AM
rxeightr's Avatar
M0D Squad -charter member
You asked if this has been reported as a common problem.
No it has not.
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
DG07
Sep 28, 2015 10:58 AM
