looking to purchase stock wheel off ebay; need info, please
Old Dec 20, 2005 | 04:54 PM
natepartlan's Avatar
Question looking to purchase stock wheel off ebay; need info, please
I am looking at a set of the 16 inch RX8 stock wheels from ebay for a non-Mazda application. Could the forum help me out with the:
width?
offset?
weight?
thanks from a Miata driver,
Nate
Attached Thumbnails looking to purchase stock wheel off ebay; need info, please-rx8-wheels.jpg
Old Dec 20, 2005 | 05:25 PM
no problem dude ...
Old Dec 20, 2005 | 05:36 PM
I may be a noob to this forum, but I'm not a noob in general! I did search first with several different combinations of several key words to no avail.
However, I did find some info off google and maybe the forum can confirm its accuracy?
diam. 16 inch
width 7.5 inch
offset 50mm
weight 16.3 lbs.
all above true?
Old Dec 20, 2005 | 05:40 PM
I was trying to do it nicely before somebody else dropped a 10 ton weight on your head they show no mercy around here sometimes
Old Dec 20, 2005 | 06:05 PM
I confirmed all the diameter/width/offset dimensions in the RX-8 parts manual
I found the same weight listed here on the forum, but frankly the scales of the members around here seem to vary as much as their opinions ...
Old Dec 20, 2005 | 06:37 PM
thanks, I thought this may be a good wheel choice to replace a 17x6.5 with 46 offset (stock tire of 215/50-17), but I think the large 50 mm offset kills it (I'll have to go sit down and crunch some math first)
BTW, looking to go with a 225/50-16 tire on a suitable wheel. I figured 7, 7.5, or 8 in wheel is good but I think I need to restrict myself to 40, 33, or 27mm offsets, respectively. or use spacers.
thoughts?
Old Dec 20, 2005 | 07:31 PM
Crunched some numbers and geometry while watching TV; I think I can do it with a 10 mm spacer and not rub suspension or fender.
Epitroch
Epitroch
Oct 24, 2015 12:04 PM
MolecularConcept
Aug 5, 2015 04:43 PM
MolecularConcept
Jul 26, 2015 09:09 PM
BamaRules777
Jul 25, 2015 08:45 PM
thedragonrotar
Jul 22, 2015 08:46 PM
