theCATALYST
12-13-2005, 12:31 PM
Would 19 x 8 in the front with a 40 mm offset and 19 x 9 in the rear with a 45 mm offset fit a stock RX8 suspension with no problems? Any help would be appreciated. Looking at a set of OZ wheels.
View Full Version : Fitment help. theCATALYST 12-13-2005, 12:31 PM Would 19 x 8 in the front with a 40 mm offset and 19 x 9 in the rear with a 45 mm offset fit a stock RX8 suspension with no problems? Any help would be appreciated. Looking at a set of OZ wheels. RA-Eight 12-13-2005, 12:46 PM Depending on tires, the front will more than likely fit. My assumption is based on x8" width I have currently with my winter, with et35+ offset. x9" rear should fit also with a +45 offset. I've seen other members running a more aggressive offset and width with no rubbing. Use the offset calculator at www.1010tires.com to get a better gauge. Which OZ wheels are you considering? theCATALYST 12-14-2005, 05:42 AM I think that they are the OZ Classe. These |
