Remove Canzoomer before Dealer Servixce?
Old Nov 29, 2005 | 04:02 PM
Spin9k's Avatar
Momentum Keeps Me Going
Question about taking car in for normal service interval... I've just put in the Canzoomer, now it's time for my regular service. I've had the gas tank blanket installed before I put the unit in and they flashed me at that point I guess.
So now should I take it out again? There is no problem with them knowing I have the unit, but ....Do they do anything to the ECU during normal service check that could harm the unit? What if they flash it again, can that harm a Canzoomer unit? Or should I just turn it off?
Confused Thanks.
Old Nov 29, 2005 | 06:23 PM
r0tor's Avatar
I don't take mine out unless I'm having some serious work done to the car - where they may end up finding while disassembling things.
Normal service visits and even flashes are not a problem.
Old Nov 30, 2005 | 10:57 AM
i would turn it off.
Old Nov 30, 2005 | 01:03 PM
Armaant's Avatar
Armaan
i turn mine off before i take it it then turn it back on when i get home...takes about 5 mins to do now
Old Nov 30, 2005 | 01:06 PM
Nemesis8's Avatar
Bigus Rotus
I pull mine out - does not take long.
Old Nov 30, 2005 | 05:52 PM
r0tor's Avatar
i don't understand the need too...
the dealer is not going to be logging your afr and any flash goes right into the pcm, not through the maf... not to mention at 0 rpm the e-manage doesn't even modify any signals anyway
cliffkemp
Dec 24, 2024 10:48 AM
Racingjunkie
Sep 29, 2015 05:05 PM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
