Some clarification please
Old Nov 29, 2005 | 02:45 PM
Transam kid 01's Avatar
The anti-ricer
There was a thread on LS2.com about if we had to choose a 4 banger...anyway...its now become a discussion about RX7/8
so can ya guys clear up some things that are being said:
I think I'd be more into rotary engines if they had any semblance of durability to them. If you're modding a rotary motor, you should pretty much plan on doing an engine swap on a regular basis.
Nice motor... just doesn't last for ****.
You have the rotor confused with the RX7...the RX8 (although not yet known...) is expected to last 120k-200k miles (as apposed the RX7's 60k) the ones in the 8 are different...give it a couple years...u'll see
no incorrect, a rotary is a rotary is a rotary. All the same concept with different parts. The engine by itself is designed to burn oil, there is no way around it. The Apex seals on the engines are the biggest concern and from what I read, the rx8 has updated seals to help with durability. They should have turbo'ed the car though because it needs more power.
Your very full of BS my good man. The only problems that occured with the rotory engine happened with the most popular of trims, the twin turbo FD's wich is why you hear about it. The N/A rotary has been known to turn 300k without effort (no rebuilds or apex seal replacements) and also recognized by the aeromotive community as one of the most reliable engines on the market for feather light air craft. Not only is the rotory one of the most reliable gas engines every made it is one of the easiest to maintian. Blow out an apex seal, takes 3 hours to rplace. Blow out a piston, your down for a week!
did you just really send me to how stuff works??LMAO ok if I do not know how a rotary engine works, how did I know about apex seals? or the fact by design the engine burns some oil??
No confusion here mogs, transam was trying to explain to you that the N/A rotary engines are very reliable and quite simply you said "no, blah blah blah blah blabbity"
like I said, you cant read. He said they are different than the rx7 engines, a rotary engine is a rotary engine. No big differences. And go to any rx8 or rx7 and read up. They do tend to burn more oil and do run rich because of their design. I think you are the one that needs some more understanding rather than going to a site like how stuff works and get a vague over view of the engine. Those sites are for people with zero engine/car knowledge.
sorry about the legnth....but i cant link to this section on Ls2 unless ur registered
Thanks for clearing things up guys
-Sean
Old Nov 29, 2005 | 02:57 PM
Glyphon's Avatar
脾臓が痛みました
N/A rotary engine can easily last in to the 200k + range. One example is when i bought my rx8, there was another rx8 owner there getting an oil change done on her car. we started talking, and i found out that the car she had before the rx8 was an FC rx7, that had almost 300k miles on it when it died. she said she could have easily fixed it, but she'd had the car for so long, she wanted something different.
the main thing that the FD rx7 had different about it was 2 turbos throwing out a ton of heat, and an inadequate cooling system. And from talking to a friend with a 95 FD, its the turbos that typically need a rebuilt at ~60k miles, not the engine, which typically last in the 80-100k range before needing a rebuild.
the reason that the rotary engine got such a bad rap was because doofs who don't know anything about rotaries would buy an FD, improperly mod it, which in turn leaned the AFR out too much and blow the engine.
And since the FD was an amazing car even when it was stock, every dumas and their grandmother wanted to buy it and then mod it, which takes us back to the doofs improperly modding their car.
mazda has largely addressed the improper modding cause of problems by using the ever-controlling ECU that is the bane of anyone trying to get more out of their car.
Old Nov 29, 2005 | 02:59 PM
The anti-ricer
Thanks dude, ill be sure to post that and give you some credit
Old Nov 29, 2005 | 03:27 PM
Im_DANomite's Avatar
I love GOOOLD
just to let you know, rotary engines aren't the only engines known to burn oil. BMWs, in fact, are supposed to burn up to 1 quart every 1000 miles.
***edit*** just to add. all engines will burn oil. some will burn more than others. unless you have total seal piston rings with absolutly NO GAP, you will always burn oil. plus, rotary engines don't have to worry about jumping time, bending valves, retainers popping out, etc. etc. there are pros and cons to everything.
Old Nov 29, 2005 | 03:38 PM
The anti-ricer
no ****! thats worse than the 8!
Old Nov 29, 2005 | 03:44 PM
Red Devil's Avatar
My '87 Turbo RX-7's original engine lasted ~150K before needing to be replaced. It was properly maintained and cared for, but was also redlined often. It ran the factory turbo at 10lbs of boost, stock was ~8.6.
The FD ruined the reputation of these engines. Mazda made a few mistakes from the factory, like the extremely complex sequential turbo set-up and all the vaccum lines associated with it. The vacuum lines were rubber, they hardened and cracked under the extreme temperatures. Replacing the rubber with silicone lines addressed this issue. Then there was the cooling issues from a plastic overflow tank and too small of a radiator. Add a larger radiator and metal overflow tank and this was no longer an issue, a downpipe replacing the pre-cat further reduced temperatures. FD's also came without boost gauges, so most couldn't readily recognize the signs that something was wrong before it was too late. Owners generally blew FD engines by running them too lean by adding straight through exhaust systems and either not adjusting the fuel, or having improper tuning performed by a shop that had no clue what they were doing. It's easy to get a lot more power out of FD's, but it has to be done carefully, not haphazardly. If the engine, 13B-REW, is properly tuned, the OEM apex seals in the FD are good for upwards of 500hp.
Old Nov 29, 2005 | 03:52 PM
Glyphon's Avatar
脾臓が痛みました
^^^ from what i've read, the fuel system on the FD wasn't up to the task of supplying enough fuel when the car was upgraded, and was the primary cause of the afr going lean, then pinging, then dying. and another way of stating the FD's stock 2mm apex seals strenght, is that they have been shown to be handle around 20lbs of boost.
Old Nov 29, 2005 | 03:59 PM
Red Devil's Avatar
I'm taking it "was up to task" you meant "wasn't up to task."
Anyway, the fuel system on the FD was capable up to around 400bhp, as I recall. But if you added a downpipe, midpipe and cat back, you needed to have fuel enrichment programmed into it with like a S-AFC type piggyback, or at that point start thinking about stand alones because you were probably upping the boost voluntarily.
Old Nov 29, 2005 | 04:02 PM
I love GOOOLD
Red Devil pretty much summed it all up in a nutshell. a friend of mine has a 1993 TT RX7 running on stock turbos, upgraded FMIC, Apexi Power FC, and mild suspension work. the car has close to 100k miles and is fuel tuned to run in the low 13's/high 12's. he takes the car for track days (not drag). the only issues he has with the car is overheating (cracked AST (the plastic tank Red Devil mentioned)), cracked vacuum lines (the nest underneath the intake manifold), and a faulty coolant temp sensor. other than those things, his RX7 can pretty much own anything on the road.
that's the only picture i have of him
Old Nov 29, 2005 | 04:07 PM
cleoent's Avatar
n00b
that guy that keeps saying a rotary is a rotary is cracking me up.
As him if all 4 cylinders are the same, actually since you're on a ls2 forum, ask him if all v8's designed from 1980 to today are all the same...
That's a pretty ridiculous arguement he's making. But, for some reason, i picture an ls2 forum to be full of uneducated shotgun wielding hillbillies, so I'm not surprised ha ha ha ha...
(present company excluded of course :D)
Old Nov 29, 2005 | 04:21 PM
I love GOOOLD
does anyone on that forum run a APS twin turbo kit on an LS2?? i would love to see some pictures. V8 Twin Turbo...that's wicked.
Old Nov 29, 2005 | 05:09 PM
The anti-ricer
lol...nah, they are biased, but very not hillbillish (lol)...im not sure why they dont get or accept the rotary engine, but then again, this isnt a wenkel site, its an Lsx site...yeah and that guy got flamed by a lot of people for that comment lol
Old Nov 29, 2005 | 05:11 PM
The anti-ricer
I just posted a thread....ill let u kno what they say...i do kno though that there are a few there with single turbos
Old Nov 29, 2005 | 05:52 PM
The anti-ricer
TT ls1 http://media.putfile.com/eboggs-LS1-TT
http://www.ls1tech.com/forums/showth...win+turbo+pics
http://www.ls1tech.com/forums/showthread.php?t=414830
Old Nov 29, 2005 | 05:53 PM
The anti-ricer
http://www.exoticperformanceplus.com...Car.php?car=22
Old Nov 29, 2005 | 06:13 PM
YT1300's Avatar
Turning and burning
Riiiight. And the Otto cycle motor hasn't come anywhere in the past 30 years, I'm sure. <sigh> Materials, people, materials - the metallurgy and the manufacturing abilities of major engine manufacturers have come a long way in the past 30 years, where you're seeing piston velocities in the range of F1 engines in small displacement Honda motors, infinitely variable valve timing, and reliable compression ratios greater than 11.0:1. And let's not forget about diesel technology advancements.
Some people just don't want to learn any more than what they think they know.
Old Nov 29, 2005 | 07:50 PM
Chrisbert's Avatar
Just like any engineering tradeoffs, the rotary trades less moving parts for slightly more oil consumption. It does not mean it has to be any less reliable than a piston engine. Actually, I'm more concerned about the cost of replacing things like the AC compressor, alternator, etc than engine repairs. The hourly labor is low on the rotary.
Old Nov 30, 2005 | 08:49 AM
Red Devil's Avatar
You know, a while back I got into a discussion because I recalled it being around 6.2psi on my 87TII. After a while I just relented because I honestly couldn't remember and went with it being at the 8.6 figure.
Now this is bothering me, so I'm going to have to look it up. It's been years since I had that car.
RicerX1
Jan 11, 2016 05:59 PM
gfailure
Purchasing, Financing, & Insurance
13
Feb 23, 2012 09:57 PM
Tyronicon
Dec 13, 2011 03:11 PM
zoom44
General Automotive
Nov 20, 2007 11:56 PM
