break in period
Old Nov 28, 2005 | 10:10 PM
DropTheHammer's Avatar
break in period
i will be picking up my car tomorrow morning , can some one please explain how to break this motor in , like how many rpm not to pass how many mph, umm and for how many miles... and all other vital info will be great
Old Nov 28, 2005 | 10:33 PM
NgoRX8's Avatar
From Racing Beat:
RX-8 Break-In
Mazda's Guidelines
The Mazda RX-8 Owners Manual lists the following information for the break-in period of a new vehicle:
"No special break-in is necessary, but a few precautions in the first 1000 KM (600 miles) may add to the performance, economy, and life of your Mazda.
- Don’t race the engine.
- Don’t maintain one constant speed for long.
- Don’t drive constantly at full-throttle or high engine RPM for extended periods of time.
- Avoid unnecessary hard stops.
- Avoid full-throttle starts."
A review of the Mazda RX-8 Service Manual Highlights revealed the following information regarding break-in:
"A fluorocarbon resin coating has been added to the trochoid surface (rotor housing) for improved initial break-in."
Racing Beat's Guidelines
The Mazda guidelines are reasonable and prudent. If you have any questions or uncertainly regarding the break-in period, we suggest you follow these official recommendations.
We receive many requests for our recommended break-in procedures. The following are Racing Beat's recommendations:
- For the first 1000 miles do not accelerate under full throttle.
- During the first 1000 miles do not exceed 4000 RPM.
- For miles 1000-2000, expand the RPM upwards - but do not accelerate at full throttle.
- Over 2000 miles, full throttle and high RPM is acceptable.
In summary, our guidelines offer a progessive method to increase the working loads placed on the engine.
Old Nov 28, 2005 | 11:53 PM
so basically like a regular car,, and thanks for the post
Old Nov 29, 2005 | 02:48 AM
NgoRX8's Avatar
No problem. Another thing:
Don't forget to check your oil level every other gas fill. Let the car warm up for a few minutes when you drive it, so the Temp will be near the middle, and don't shut off the engine when cold.
Good luck!
Old Nov 29, 2005 | 07:38 AM
yiksing's Avatar
the giant tastetickles
I let the car warmed up (oil and water temperature) for a while and hammer the car as soon as I got it.
Old Nov 29, 2005 | 11:38 PM
ngo thanks again will do.. doesnt seem its going 2 be a hasle
Old Nov 30, 2005 | 08:26 AM
KYLiquid's Avatar
Oil Injection
i did the RB breakin and then switched to all syn fluids at 8K miles. I made it to 10600 miles with 0 problem, now its sitting at the dealer needing new coil packs....but thats unrelated to the breakin.
Old Dec 2, 2005 | 10:54 PM
is this common?
Old Dec 2, 2005 | 11:23 PM
rogue2's Avatar
I drove mine pretty conservatively for the first 1000 miles. After that i pretty much lost my head and just started driving the (four letter word here) out of it. I get regular maintenance, check the oil every couple hundred miles (i have a little O.C.D.) and check the tire pressure once a day (again with the O.C.D.) 13,200 miles and counting and no problems.
R3Dream
48
Mar 12, 2016 01:44 PM
snowrydr01
Nov 23, 2015 09:40 AM
juicemantwon
Sep 26, 2015 12:30 PM
tgaffner
Sep 7, 2015 08:49 PM
