View Full Version : Kazera KZ-A's ?
smith007
11-28-2005, 09:09 PM
Just got some new Falken Azenis 615's (245/40/18's) so i'm thinking about ugrading to these rims but i figured i'd get some feedback first.
http://www.tirerack.com/servlet/CallJsp?target=wheelSearchCloseUp&wheelIndex=21&sizeIndex=0&showRear=no&setIndex=4&filterSize=&filterFinish=&filterSpecial=
Those are the black Kazera KZ-a's with +45mm offset?..anyone know how well that will work?..thanks in advance :mdrmed:
swoope
11-28-2005, 10:42 PM
not sure what you are asking, but.
they are from the tire rack, so tpms will fit. they are the correct offset and i guess the size is correct your link has timed out.
probably 18 x8 which is the right size. tires will fit those rims and the car.
speedo will read a bit low.
hope this helps.
RX4life
11-29-2005, 02:20 AM
that offset will clear easily.. and you could go wider with those tires.. im running 9.5 with barely any stretch.
MrWigggles
11-29-2005, 03:47 AM
I have those KZ-A rims (in silver not black) and if you do a search you should find pics of it.
I have the 9.5" in the rear which I believe are +42mm with 275/35 tires. That set-up fits just about perfectly - the tire is 100% flush with the fender down with no more than a couple mm of over/underhang. It works perfectly.
I used to have very very mild rubbing but that is gone now for whatever reason.
I also went with 245/40's on 8.5" +45mm rims in the front and they work very well and also line-up pretty well with the fenders.
-Mr. Wigggles
L8APEX
11-29-2005, 06:49 AM
it will actually read a bit high.
http://www.1010tires.com/TireSizeCalculator.asp?action=submit
swoope
11-29-2005, 10:22 AM
sorry mean you will be going slower than indicated.
thx.
