Seat install, airbag question??
Old Nov 21, 2005 | 04:01 PM
Need For Speed's Avatar
SPEED-8
i have install Bride seats.
i have a question?
how i have to conect the oem seat airbag to kep them work?
Old Nov 21, 2005 | 04:18 PM
SPEED-8
this are the seat i have install.
and pic of the seat on mi car.
Attached Thumbnails Seat install, airbag question??-gias_image.gif   Seat install, airbag question??-imagen-0741.jpg
Old Nov 21, 2005 | 04:20 PM
expo1's Avatar
He's as bad as Can
you should provide a link to what you installed. Why would you expect an after market seat ( if that is what you have) to work with the MAZDA OEM seat connectors?
EDIT: Now that I know what you have those seats do not have air bags in them. There is no reason to expect them to connect to the OEM seat connectors. Get used to the flashing Air bag light. The other air bags should work FYI.
Old Nov 21, 2005 | 04:28 PM
SPEED-8
pics from the seats and a pic from the seats on the car.
Old Nov 21, 2005 | 04:31 PM
SPEED-8
on the seat belt there is a conector that guive information to the airbag system, the oenm seta belt i keep it on the new one but the conector is on the oem seats, so i'm shore the front airbags can not work and mazda tell me the same.
Old Nov 21, 2005 | 04:50 PM
ScudRunner's Avatar
On time, on target
Here's what I did. I pulled the wiring harness out of the stock seat, and left it in the car. This let me keep the seat belt switch and the seat track position sensor, so that the OEM airbag sensor was still getting the information it wanted. Then, I put a 1/2W 2 Ohm resistor in the side airbag wiring harness to fake the signal from the side air bag. This keeps the airbag light from going off, and should keep the front airbags functional the way they are supposed to be.
*Disclaimer* I am a tall person and keep my seat all the way back. From what I could tell, the seat track position sensor on the OEM seat only sends its signal when the seat is forward of a certain point. So, since mine is hooked up but not sending a signal, the front airbag should still do a full, two inflator inflation should it ever go off (as opposed to the one inflator inflation it does if it gets the signal that the driver's seat is close to the airbag). I could be wrong.
Old Nov 21, 2005 | 07:23 PM
SPEED-8
thanks for the information.
its posibol to send me pics of the install P.M
Old Mar 1, 2008 | 11:05 AM
R888's Avatar
WedsSport Member
where to get the 1/2 W 2 Ohm resistor?
Old Mar 20, 2008 | 05:00 PM
hscrash's Avatar
Possibly from Radioshack.
Is there any D.I.Y. on this?
Im too far away from these electric shizzle.
Old Mar 20, 2008 | 05:11 PM
Revvittupp's Avatar
I'm astounded that you haven't gotten FLOODED with questions about your passthru... in 3...2...1....
Old Mar 22, 2008 | 06:46 PM
R888's Avatar
WedsSport Member
any DIY?
Old Mar 22, 2008 | 06:52 PM
Cody Red's Avatar
always filling [the c]up
a diy would be great.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
MolecularConcept
Aug 5, 2015 04:43 PM
AussieGray
Jul 16, 2015 03:58 AM
