Any porblems with remote starters on AT
Old Nov 19, 2005 | 10:41 PM
mauricio's Avatar
Angry Any porblems with remote starters on AT
I had a remote starter added to the vehicle and It the car tries to start but then goes off it tries again and again I have to take it back but is there any reason why this happens other than the installer did not do it correctly?
Old Nov 20, 2005 | 03:19 AM
lazi's Avatar
drivelinestore.com
easy fix. all you have to go is "re" set the ignition timer. there are different sets u can set the seconds on it. i had to do that myself. i had the same problem. it was fixed in 1 min haha. =)
-Sam
Old Nov 21, 2005 | 03:54 AM
YT1300's Avatar
Turning and burning
See above. Needs to crank longer.
Old Dec 11, 2005 | 12:49 AM
mauricio's Avatar
It was set to crank longer but again the second day starting from cold it did the same thing.
2nd it was to the tachometer but still did the same thing @ cold last they said they going to try some electronic to piggy back with the starter device but why so much trouble?
Old Dec 13, 2005 | 08:10 PM
orange0303's Avatar
TSR-SE3P (NA TUNE)
well
the auto-start flooded my engine.. so i am going to take that out
Old Dec 13, 2005 | 08:26 PM
lazi's Avatar
drivelinestore.com
Originally Posted by orange0303
well
i really believe its cause the ignition second timer. its set to short on default. you'll need to set it higher around 2.7 seconds.. i thinks thats wut mine is on.. on my Viper remote starter
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Quiggs321
Sep 30, 2015 05:34 PM
pjwermuth
Sep 28, 2015 11:36 PM
