how do you know.....
Old Nov 18, 2005 | 02:27 AM
xrider01's Avatar
......when your clutch is starting to give out?
i'm not sure if it's just me not applying proper amount of force to my clutch, or if it's actually my clutch that is starting to give way. my car only has 22.5k miles on it. while not "brand new", it still should have easily another 40k miles to go before it should be replaced i think. i've seen some of you guys out there already replaced your clutch, and i saw one where the throwout bearing had eaten up the clutch plate.
for those of you who have already replaced your clutch, was it because of failure, or because you wanted to do it?
Old Nov 18, 2005 | 07:52 AM
cas2themoe's Avatar
PoloRican Rotary
I replaced my Clutch, Flywheel and Pressure plate because I wanted a faster/stronger grab on the gears. I dont recall many people saying they replaced the clutch because of problems. But I do recall 1 person. But thats it.
Old Nov 18, 2005 | 07:54 AM
Go48's Avatar
There are several threads about failing clutches. Do a search.
Old Nov 18, 2005 | 11:14 AM
staticlag's Avatar
The Professor
Once a clutch is worn out, it will start slipping.
While going at a steady speed, quickly give your car WOT, if you see the RPM needle raise and your car shows a sluggish/no response while the needle itself does move, then your clutch is slipping.
Old Nov 18, 2005 | 11:18 AM
Nubo's Avatar
Lubricious
Usually you'll notice a worn clutch when you're trying to accelerate quickly, or when climbing a steep hill. The rpm will shoot up faster than you'd expect from the speed of the car. That is, the engine is going faster than the drivetrain because the clutch is slipping. Once that starts it isn't long before it will be slipping even on a flat road at steady speed.
Old Nov 18, 2005 | 11:20 AM
xrider01's Avatar
what does WOT mean? i see that being said all over the place, and still don't know what it means .
so, my clutch isn't slipping then . what about the gears not going in smoothly? namely 2nd and 5th gear. sometimes when i go to shift, the gears won't go in all the way and my gear box starts to grind. i take it, that's just user error then huh? lol
Old Nov 18, 2005 | 11:23 AM
staticlag's Avatar
The Professor
WOT = Wide Open Throttle = Pedal pressed all the way down as far as it will go
Old Nov 18, 2005 | 11:29 AM
xrider01's Avatar
gotcha
Old Nov 18, 2005 | 01:22 PM
Krankor's Avatar
Klingon Grammarian
xrider01, people use a LOT of abbreviations around here (too many, if you ask me). It turns out, there's a really useful list defining them, which, unfortunately is hidden away down in the basement in an unused lavatory behind a sign saying "Beware the Leopard". You have to go to this forum (RX-8 Discussion), then at the top, ahead of the threads, there's a list of sub-forums, one of which is "The RX-8 FAQ", and then *next to that* you can click on "Faq - Update". which is a thread, and then the second post in that thread is a most excellent cryptic-abbreviation rosetta stone.
I have been complaining since I got here that that stuff is too hard to find.
Old Nov 18, 2005 | 02:02 PM
KYLiquid's Avatar
Oil Injection
I lowered my floor, so my car will go WOT more than yours just kidding.
You will notice it in higher gears at first, more load in the higher gears...as other have said its when you go WOT or put a lot of load on the motor, driving up a steep road, ect.
and OEM clutch in a stock car (with little to no abuse) should last at least half the life of the car, My friend has a stock MX6 with a stock clutch in it, around 160k miles on the clock now.
Old Nov 18, 2005 | 02:58 PM
xrider01's Avatar
i know about abbreviations . it's just that i hadn't heard about WOT before until i came to this forum.
8u7 !75 411 48ou7 r43d!ng !n 1337 5p43k. 488r3v!47!0ns 4r3 p0!n71355 !f y0u c4n'7 r34d !n 1337 5p34k
dynomight
27
Mar 4, 2010 12:30 AM
vndr09
32
Jan 6, 2009 10:37 AM
peanutbuster85
Aug 23, 2008 07:20 PM
ym3n3
25
Jan 6, 2008 04:01 PM
R888
Jun 2, 2007 02:05 PM
