what oil is in the car when you buy it?
Old Nov 15, 2005 | 05:38 PM
miater's Avatar
anyone know what Mazda uses?
Old Nov 15, 2005 | 05:41 PM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
Probably what they supply to the dealerships that use Mazda rotary oil (5W-20, a semi-synthetic blend, I believe).
Old Nov 15, 2005 | 07:22 PM
miater's Avatar
I 'm wondering who makes the 'mazda' oil?
Old Nov 16, 2005 | 11:13 AM
KYLiquid's Avatar
Oil Injection
its a 5w20, im not sure who makes it, is it the shell helix?
Old Nov 16, 2005 | 01:40 PM
miater's Avatar
all it says on the bottle is 'distributed by mazda' , and is it really semisynthetic? I 'll keep buying it at the dealer, may as well stick with it i'd guess.
Old Nov 18, 2005 | 12:00 PM
crossbow's Avatar
In the 6's, its motorcraft 5w-20 semi-syn. Its really hard to identify inital oils, as all the engine lubes mix in and screw up the chemical analysis.
Old Nov 18, 2005 | 12:32 PM
ZoomZoomH's Avatar
Mulligan User
whatever the Hiroshima plant gets when they built the motor.... Idemitsu?
Old Nov 18, 2005 | 07:16 PM
miater's Avatar
zoomzoomH and crossbow seem to disagree......
Old Nov 18, 2005 | 08:39 PM
ZoomZoomH's Avatar
Mulligan User
not disagreeing at all, as a matter of fact we sort of agree, that they fill the engine with whatever oil is available at the local plant
US Mazda6 = built in US = Motorcraft oil
US RX-8 = built in Japan = Japanese brand oil
Old Nov 18, 2005 | 08:48 PM
tiggerlee's Avatar
May Cause Anal Leakage
Ok so maybe I'm misunderstanding some posts so can someone clarify?
Are you asking what oil Mazda uses when they roll an 8 off the assembly line?
OR
Are you asking what oil the dealership uses where you purchased your 8?
Old Nov 18, 2005 | 09:14 PM
miater's Avatar
what oil is in it rolling off the assembly line.....
Old Nov 18, 2005 | 09:19 PM
tiggerlee's Avatar
OK Thanks! I think it was the title of the thread,then the responses that had me confuzzled.
Old Nov 18, 2005 | 10:11 PM
RotoRocket's Avatar
Freely Radical
I hope it WAS NOT the same oil from the factory.
My car had just over 40 miles on it when I bought it new, at the end of September (this year), and it was built 14 months earlier.
Old Nov 18, 2005 | 10:41 PM
ZoomZoomH's Avatar
Mulligan User
^most likely it IS factory oil sitting in the engine for 14 months.... that's why you change the oil asap!!!
Old Nov 18, 2005 | 10:45 PM
tiggerlee's Avatar
That was condition of purchase when I bought mine. Even though it was an '05 and hadn't been on the lot long, I demanded fresh oil and a full tank of gas before I signed the papers.
mr. GrandGame
Sep 9, 2025 10:41 PM
Skyl3r
Dec 2, 2019 04:51 PM
Junirol
Sep 22, 2015 06:02 AM
RotaryRider
Jul 20, 2015 07:05 AM
