Charcoal Canister
Old Nov 14, 2005 | 08:30 PM
Helmano's Avatar
Charcoal Canister
I need to get to the charcoal canister which is located in the rear under the trunk. My car runs perfect but the check engine light is on because of that. I was told that mazda pretty much built the car around it. Has anyone done this or does anyone know a good or somewhat easy way to get it? Any help would be appreciated.
-Kevin
Old Nov 14, 2005 | 08:31 PM
army_rx8's Avatar
X-Sapper
how do you know it's the charcoal canister...what code are you throwing?
Old Nov 15, 2005 | 10:00 AM
Helmano's Avatar
i went down to my dealership and they said thats what it was. When my buddies and I were putting my suspension on my car I had to remove my subs and all of the other stuff i did in my trunk. when i was putting the sub box back in they said i drilled a small hole into the charcoal canister. i had no idea it was right under the trunk. the service guys told me its $321 for a new canister and $300 for the labor to install it. I would rather see if i can get to it and just close up that hole since nothing is wrong with my car.
Old Nov 15, 2005 | 12:03 PM
Go48's Avatar
I hope you didn't drill into the gas tank. It's back there too, ya know?
Old Nov 15, 2005 | 12:06 PM
Nemesis8's Avatar
Bigus Rotus
Try Paul at Mazmart
https://www.rx8club.com/mazmart-88/
Warrior777
Jun 24, 2019 04:47 PM
Yusik
Feb 1, 2012 03:50 PM
