engine coolant
Old Nov 13, 2005 | 12:05 AM
kraji's Avatar
engine coolant
my engine coolant is low how should i top it off?
i was reading the manual and it said i have to mix with
water??
anyways i bought sum engine coolant fluid today
called prestone or somthing? so umm.. what should i do?
how should i top off the coolant?
Old Nov 13, 2005 | 01:21 AM
Old Rotor's Avatar
More important is why is it low!! I have had many rotary engines and if it is low where did it leak too? The overflow or expantion tank, is it empty? Was it ever checked before? You have a sealed system and when the water gets hot it goes into expantion tank. If you have a leak somewhere it will empty out and then start empting your cooling system. Find out where it is leaking. You should not have to be adding water. Mix it according to the coolant instructions. Do you see a puddle under your car? How much water was missing?
Old Nov 13, 2005 | 01:27 AM
kraji's Avatar
well i never seen any leakage in my coolant. and when i start my engile i see water dripping fromt he exhaust but thats normal isnt it?
yeah my coolant is sealed correctly
thats why i find it werid that its some how low
Old Nov 13, 2005 | 01:50 AM
9G Redline's Avatar
Trolling since 2004
My coolant light comes on every now and then too. It kinda freaks me out considering how much I love my car and try to take care of it. I've never seen a puddle under my car and I do walk-arounds every time I drive her.
Old Nov 13, 2005 | 08:56 AM
NoTears316's Avatar
Shock and Awe
You may want to ensure that you arent getting any coolant into your oil. That would be bad.
Old Nov 13, 2005 | 10:38 AM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
Yeah, let a mechanic be your friend.
Old Nov 13, 2005 | 12:43 PM
kraji's Avatar
engine coolant fluid can get into engile oil?
Old Nov 13, 2005 | 01:21 PM
Brice-RX8's Avatar
Is it possible that coolant/water gets hot enough to evaporate off?
Old Nov 13, 2005 | 02:44 PM
Go48's Avatar
It's a closed system, so unless you overheat the engine causing the coolant system to exceed the 16 psi pressure that contains the coolant in the system, it ain't gonna evaporate. Overheat the engine to the point of overcoming the containment and yeah, it will likely "evaporate" in a pretty violent manner.
Old Nov 13, 2005 | 07:15 PM
NoTears316's Avatar
Shock and Awe
It's not something that just happens, but yes, if something is wrong it is possible. If you find an indication of engine oil in your coolant area it could be an indication of an engine or radiator problem. When you check your oil, it will have more of a "chocolate shake" appearance.
Old Nov 13, 2005 | 07:22 PM
army_rx8's Avatar
X-Sapper
^yes brown and chocolate chake liek..is a sign of contamination..might stick too (btu not too much if it was thicker it wodl stink real bad)
Old Nov 14, 2005 | 01:59 AM
kraji's Avatar
what would happen if the coolant is over filled?
Old Nov 14, 2005 | 02:05 AM
staticlag's Avatar
The Professor
explosion
Old Nov 14, 2005 | 02:21 AM
staticlag's Avatar
The Professor
Overheating the engine past 16 psi will cause the water to evaporate out of the pressure cap, causing you to lose liquid. But as long as the cap is working correctly, the system will remain at 16 psi, though liquid will be lost. If you have a hole or a leak on the other hand, the pressure will instantly want to drop to zero inside the system, causing an ole faithful type explosion.
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
MarkX
Jul 31, 2015 07:50 AM
dmac1961
Jul 24, 2015 11:27 AM
