Oil Change
Old Nov 7, 2005 | 11:48 PM
LiLDevil's Avatar
Oil Change
Well is that time where i need an oil change for my rx8, is there a DIY for this other than looking at the manual, any videos or pic some1 has posted that shows where the filter is and maybe easy steps i can take.. thank you!
Old Nov 7, 2005 | 11:51 PM
ZoomZoomH's Avatar
Mulligan User
yes there is a DIY for oil change, in the (DUH) DIY section of this forum
please be proactive and do a search, we're not your nanny you know
Old Nov 8, 2005 | 12:10 PM
strokercharged95gt's Avatar
its between the intake manifold and firewall. DIY??, you dont need insturction on how to change your oil unless your a newb
Old Nov 8, 2005 | 01:48 PM
ZoomZoomH's Avatar
Mulligan User
a non-n00b would've never asked such question in the first place....
Old Nov 8, 2005 | 02:34 PM
JonsToy's Avatar
Registered Rep
It's not rocket science. Most folks don't need a DIY to change the oil in their cars. Drain the oil from the pan, replace the filter, fill with oil and you're good to go. Let's not make a mountain out of a molehill.
On the other hand, I have learned two important things by following these oil change threads. Jacking up the car on the driver's side (North American) will drain more dirty oil from the pan than keeping the car level. Also, wrap the base of the filter with old rags and pop a small hole in the top of the old filter before removal. This will encourage the oil in the filter to empty back into the motor instead of all over the motor as you remove it.
You might also wait a while after you've run the motor until it cools off before you try to remove the filter by hand. I'm still nursing a fair sized burn on the back of my right wrist after removing my filter this weekend. I'm still not quite sure what I burned it on!
Old Nov 8, 2005 | 04:47 PM
Glyphon's Avatar
脾臓が痛みました
my guess would be the engine
and from what i under stand jacking one side of the car up helps drain some of the oil out of the oil coolers, and i think that if you have the 6MT, you need to jack both sides up to drain both coolers.
Old Nov 8, 2005 | 05:39 PM
bgreene's Avatar
Time of your life, kid...
just remember that if you drain more dirty, you need to add more clean......
(since there are noob's in the room)
Old Nov 8, 2005 | 05:45 PM
Glyphon's Avatar
脾臓が痛みました
^^^ yup. my last oil change was around 5qts
Old Nov 8, 2005 | 06:31 PM
therm8's Avatar
Bummed, but bring on OU!
So everyone ribbed the guy/gal for wanting a DIY, then proceed to point out all the benefits of a DIY...
Old Nov 8, 2005 | 07:30 PM
Glyphon's Avatar
脾臓が痛みました
only the first 2 posts were ribbing the op.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
