Question From Barry
Old Nov 6, 2005 | 01:20 PM
Barry Gross's Avatar
Question From Barry
Hey Guys, my new 2005 RX-8 would not start this morning. I keep getting the symbol on the dashboard of the immobilizer ( a key inside a car symbol). That is the only key I have as the dealer, who is located of state, is ordering another master and a valet key. I guess I will have to have the local dealer do whatever is done to make the car recognize the key...and will most likely have to have it towed. Has anybody else had this problem?
Old Nov 6, 2005 | 01:29 PM
shinka213's Avatar
Pettit fangurl <3
sorry cant help ya there!!
did the car start before???
if so, maybe if you disconnect the battery and reconnect it will reprogram...
not sure if that'll work but it maybe worth a try!
Old Nov 6, 2005 | 01:52 PM
expo1's Avatar
He's as bad as Can
Check for blown fuses. Also are there any devices in or around the car that give off radio waves? Something could be causing interference.
Old Nov 6, 2005 | 03:38 PM
StealthTL's Avatar
Metatron
Fuse....
ExpoGuy is on the right track, my guess would be the ECU fuse, top middle, underhood, 30 amp.
Hope it's that simple.....
S
Old Nov 6, 2005 | 05:47 PM
beachdog's Avatar
You can also try locking and unlocking the driver door with the key in the lock.
Does the remote lock and unlock the car?
Old Nov 6, 2005 | 10:39 PM
Zuhalter Vati's Avatar
Did you read through the manual? There is a section in there that talks about having problems if you have other "Electronic" Keys/cards on the keychain, or metal touching the key or ignition. Just a thought... if I had the manual handy I would post a page number.
Old Nov 7, 2005 | 12:49 AM
pot8r's Avatar
I had the same problem when I had both the key for the 8 and the key for the 3 on the same keychain. Sometimes, the immobilizer kicked in and I would turn the key, and... nothing. I no longer carry both keys at the same time.
Old Nov 7, 2005 | 07:11 AM
There is nothing else attached to the master key. To get into the car I had to use the key manually as the car will not respond to its electronic signal. Hopefully it's not a major problem and will be fixed today. Thanks for the feedback.
Old Nov 7, 2005 | 06:35 PM
Well, after almost three hours of waiting the tow truck picked up my little red baby and towed her to the local dealership. Later this afternoon I received a frantic call from the service dept. asking if I had the key to the ignition. Apparently the tow truck driver had it and forgot to pass it on. Hopefully I will get my little machine back tomorrow. One service tech type said it might be as simple as just a bad battery.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
