Baking Tailights LED in Jeopardy?
Old Nov 5, 2005 | 03:37 PM
truemagellen's Avatar
Attracts tree branches
Exclamation Baking Tailights LED in Jeopardy?
any recommendations on seperating the tailight lense from the assembly? I want to do some work inside....I know for the front you can bake it
what temp do you bake?
the back has LEDs built in...I'm thinking those will blow am I right?
how about a heat gun or solvent?
Help please thanks!
Old Nov 5, 2005 | 04:04 PM
adrian-1's Avatar
Ex- member.
goodluck. only advice I can give is to checkout the wrx's board. Here's one thread I found.
Old Nov 5, 2005 | 04:06 PM
thanks adrian, always helpful
Old Nov 5, 2005 | 09:14 PM
cgrx's Avatar
DRIVEN
I've wondered the same thing. Hopefully the keyhole part isn't too tricky either...
Old Nov 6, 2005 | 03:00 AM
i'm going to try a hat gun first then bake
Old Nov 6, 2005 | 03:41 AM
rx8spiritR's Avatar
----Got Rice?----
i've tried heat gun already, it didn't work at all, it melt my lense too.
Old Nov 6, 2005 | 03:43 AM
thanks bud...even a 200 degree setting?
I'm going to check the heat tolerance of an led...first...if it works at (200F baking) then I'll bake the lense
Old Nov 6, 2005 | 03:45 AM
cgrx's Avatar
DRIVEN
I'd bake if the LEDs can tolerate it
Old Nov 6, 2005 | 03:46 AM
I'm researching that now online...not much info
Old Nov 6, 2005 | 03:50 AM
this is an inference not direct info but LEDs are usually a plastic or resin that needs to be heated and melted into a mold during creation...so I'm going to guess it is ok but I'll reasearch a bit more to be safe
Old Nov 6, 2005 | 10:57 AM
RotaryNoob's Avatar
Hi
Buy a taillight off ebay and test it there first. I'd be willing to pitch in on a test just to see if it's viable.
Old Nov 6, 2005 | 11:22 AM
https://www.rx8club.com/showthread.p...9&page=6&pp=15
Old Nov 21, 2005 | 10:24 AM
MADIZM's Avatar
I just melted a taillight by baking at 225 for 20 min. Even after melting I still couldn't get the lens removed from the housing so don't try it.
Old Nov 21, 2005 | 10:26 AM
I hope this was a test tailight
damn mazda on this one
Old Nov 21, 2005 | 10:28 AM
MADIZM's Avatar
No it wasn't a test light doh! I had a WRX before and did the headlight baking many times with no issues. So I had condensation in my taillight took it off and saw there was water in there. Figured it'd be a good time to try to seperate the lights and paint them like i've always wanted to. Now I'm taillightless.....
Old Jan 1, 2006 | 05:54 AM
momo's Avatar
Registered Laker's Fan
Back form the dead...
I didn't want to start a new thread so I resuscitated this topic. Anywho I found this on ebay. I don't know if Truemagellen, or anyone else for that matter, had any success opening/painting the taillights? Has anyone tried this product?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Jan 1, 2006 | 10:26 AM
yes someone did paint the lense seemed to turn out well
I was trying to paint the insides
baking was virtually impossible I gave up pretty much
Old Jan 1, 2006 | 11:06 PM
momo's Avatar
So, no one has tried this film product? I think it is a cheap alternative to buying an extra set of tailights, should you f-them up. This film can be removed if it is unsightly. When I get some extra skrill I will buy a roll.
Old Jan 2, 2006 | 06:03 AM
yiksing's Avatar
the giant tastetickles
You could check the Mazda 6 owner's manual, my friend (a 6 owner) said it contains instruction on how to bake the thing after disassembling.
RX8mzda
Oct 14, 2015 05:12 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
Stubbs
Jul 28, 2015 09:23 PM
