Help ms bodykit knockoff in Canada?
Old Nov 3, 2005 | 09:35 PM
tral's Avatar
Hey anyone know where i can order a ms speed knock off body kit in canda cant afford the real thing, im specifically in edmonton. Any one in canada bought and installed such a kit, if so how much, fit, wear? im worried that the extreme cold days would ruin a fiberglass kit, would urithane be better? How much to get the body shop to paint it/ fit it. Anyone know where in edmonton to have it done?
Thanks a ton for any help!!
Old Nov 3, 2005 | 10:08 PM
tral's Avatar
Also with the instal of the kit do u have to ruin the stock front or rear to put on the kit, ie. if the kit ended up getting damaged or i dont like it can i go back to stock or is it ruined to put on the kit?
Old Nov 4, 2005 | 01:43 AM
Jabberwock's Avatar
There is a lot of cutting and hacking to the rear, but everything should look fine if you go back to stock. Removing the side skirts after the install may cause problems, depending where you drilled the holes to mount them.
Old Dec 24, 2005 | 07:28 AM
Bad_Karma_RX8's Avatar
A lot of the replica MS kits do a complete bumper replace vice cutting like the original kit does, but if you go with the replica get urethane vice fiberglass. That of course is my own opinion.
Old Dec 24, 2005 | 02:07 PM
BlueFrenzy's Avatar
Rotary Powered Decepticon
Tral ... you are one lucky bastard in that Canzoomer (a vendor here) sells replica MS kits for a reasonable price and he is located in EDMONTON. He's local to you so you can probably get info from the man himself on the fitment.
Old Dec 24, 2005 | 02:25 PM
Terrance26's Avatar
8 all the way
urethane is always better than fiberglass.
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
1webbdan
Oct 31, 2015 07:57 AM
Sheldon24
Sep 21, 2015 04:53 PM
Sheldon24
Sep 19, 2015 02:37 PM
