rx8 05 auto peel out
Old Nov 2, 2005 | 12:09 AM
kraji's Avatar
rx8 auto dont have enough hp to peel out right?
for example say that you juss step on it when ur at complete stop
theres no way 05 auto can peel out right?
Old Nov 2, 2005 | 12:19 AM
playdoh43's Avatar
um, i think peeling out has more to do with torque than horsepower. the auto has more torque than the 6mt.
Old Nov 2, 2005 | 12:27 AM
staticlag's Avatar
The Professor
peeling out depends more on tire and road condition than anything else. Not really a good estimate of power.
Old Nov 2, 2005 | 02:14 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
The only times I ever burned rubber with the automatic (I used to own) was by performing a neutral slam (putting the shifter into neutral, revving to 5000 - 6000 RPM, and then dropping the shifter into drive). And it wasn't even impressive anyway.
If your urge to make your automatic peel out is that high, you'll have to do it at the expense of your transmission. I really don't recommend it. If you care about peel outs and that type of **** so much, you either A) should have bought this car in stick, or B) should have bought a different automatic vehicle with lots of torque.
Old Nov 2, 2005 | 02:17 AM
Vertigo-1's Avatar
Probably not going to be able to, the traction control is just simply too damn good on the RX-8. Since getting the R flash, I've been able to consistently get my RX-8 to deliver a "kick" to the rear wheels doing a redline shift from 1st to 2nd (a pretty good sign IMO that the R flash does indeed deliver more power, this never happened prior to the R flash), similar feel that you get when popping the clutch on a redline 1-2 shift on a manual. But the tires never squeel, you just simply feel the kick...I'm guessing traction control's simply too good.
Old Nov 2, 2005 | 06:31 AM
Mugatu's Avatar
Even My Dog Searches
oh god...
Old Nov 2, 2005 | 07:02 AM
8_is_enuf's Avatar
Rig up some James Bond oil squirters.
Old Nov 2, 2005 | 07:23 AM
crossbow's Avatar
Go to pepboys and buy the cheapest all-season tire they offer. You'll peel out without issue.
Loss of traction is never a good thing. Think it is? Try doing jumping jacks on ice.
Old Nov 2, 2005 | 07:31 AM
StewC625's Avatar
Insanely Yellow
Keeping the family guy thing ...
While I have an MT, I drove an AT recently in California (Would you believe that Hertz at LAX has one? I rented my own car from Hertz (albeit with an automatic)! It was a base automatic car.
Anyway, I could easily burn rubber in that car if I brake-torqued it prior to take off ... and if you slipped the brakes slightly, you could set the rear wheels spinning and do a very healthy burnout if you modulated the brake pedal well.
Not that I did such an abusive thing to a rental car. Especially in the parking garage of a hotel. Heavens no!
Old Nov 2, 2005 | 08:35 AM
willhave8's Avatar
Originally Posted by Mugatu
oh god...
Well said... DITTO... Combine this thread with the one who's buddy wants to race him for $500 and we have twins
Old Nov 2, 2005 | 11:15 AM
KYLiquid's Avatar
Oil Injection
if you just want to be able to sit at a stop light, punch the gas, and peel out.....good luck.
My dad is a vette fan, even in his 94 (360hp/345tq) at the wheels, when he punches it from a stop light, there is a quick chirp and the car shoots off.
the limiting factors are the tires, tq converter and gearing....set those up a certain way and youll be able to do it.......of course that means setting it up the exact opposite way you would if you wanted a good, well driving sports car.
Old Nov 2, 2005 | 12:17 PM
NgoRX8's Avatar
I say set it up the opposite way...
Old Nov 3, 2005 | 02:16 AM
kraji's Avatar
wouldent that **** up your car? by revin 5 - 6 k and shiftin to drive?
Old Nov 3, 2005 | 02:42 PM
Fsunoles06's Avatar
one time wont really do anything, make a habit of it and kiss your tranny goodbye.
Old Nov 7, 2005 | 11:47 PM
ShadowX's Avatar
Funny enough, I was thinking the same thing the other day. I'm just so used to dropping the clutch, always wondered if the auto RX8 could do it.
Old Nov 8, 2005 | 08:52 PM
Anyone want to take bets that the 06 AT won't be able to either?
Shinka84
Aug 19, 2015 04:55 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
xandersonx97
Aug 2, 2015 01:02 AM
Jazzmeson
Jul 31, 2015 01:48 AM
Jazzmeson
Jul 31, 2015 01:47 AM
