My EDFC cause trouble
Old Oct 28, 2005 | 06:58 PM
black-rx8-msbodykit's Avatar
hi guys, i have tein flex coilver and EDFC control, i had them for about half year, everything works fine. But few weeks ago, every time i turn on my car my DSC is flashing and also the "car slipping" light is always on, i kind ignore those lights, but yesterday i bring my car to the dealership, they did few recall, when i picked up today, they told me the power steering doesn't work. After few hour of checking, they find out my EDFC is connected to my power steering, and that's the problem that made my wheel hard to turn, so they disconnected my EDFC, and my power steering is working again. Anyone have this kind trouble with the Tein EDFC? Should i try to connect my EDFC again or take it out? BTW without the edfc, my car handling is not as good, it feel kind loose.
Old Oct 29, 2005 | 01:40 PM
gr8rx's Avatar
the edfc shouldnt be connected to the power steering, as far as I know it has motors that attach to the top of the strut and thats it. the only other connections it should have is an power and a ground. If this is indeed the case then there is no reason that the edfc would cause your power steering to fail..........basically dealer BS, unless hooked up way wrong.
Old Oct 30, 2005 | 03:58 AM
foo77's Avatar
4th batch : Apr 03'
i have tein flex on my 8 on July although i don't have EDFC, i feel comfortable with it until now
Old Oct 30, 2005 | 11:13 PM
Mikelikes2drive's Avatar
OP didnt you sell ur car for a corvette long ago?
Old Oct 31, 2005 | 10:33 AM
devoid's Avatar
My doctor prescribed RX-8
If you had your EDFC installed by a TEIN dealer, this is bad...really bad. If you did this, shame on you! The EDFC should draw its power straight from the battery, period. Run a power line to connect to the battery. Run the accessory on wire to whatever accessory on wire you want. It's not that tough. But you really shouldn't be putting any sort of strain like the EDFC on any factory wiring.
WranglerFan
Aug 21, 2022 01:29 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
