Need to know what to do
Old Oct 24, 2005 | 08:19 PM
cooldriver88's Avatar
I'm planning on getting more bump in my trunk between 600-800 watts RMS and I want to know what I need to do, Like do I need a new alternator? Bigger battery?
And where should I go to get the stuff to power the soon to come system?
-Derek
Old Oct 25, 2005 | 02:43 PM
forbidden's Avatar
Read the grounding sticky at the top of the forum for starters. Next the search button is your friend.
Old Oct 25, 2005 | 03:18 PM
rkostolni's Avatar
I haven't had any problems with the electrical system yet and am running a 1000/1, but I'll let you know in a couple of years when the alternator starts to age. Still stock battery and alternator with no cap. I will probably be upgrading to an Optima battery very soon though.
Old Oct 25, 2005 | 04:30 PM
juiceRx8's Avatar
Did u Knw Ur Grlz on my..
If you are looking for a good amp that will put out 600rms into a single channel (mono), than the Alpine mrd-m605 is your best bet cause since it's a digital amp it only draws 13 amps max. That's comparible to a analog amp drawing 60-65 amps. your alternator will last a hell of alot longer.
