270 whp
Old Oct 19, 2005 | 12:21 PM
cretinx's Avatar
270 whp
With just the GReddy turbo kit I made 214 whp @ 6 psi.
Then I got a custom straight through exhaust and the RP catless midpipe. The exhaust is trick - its a single 3" from the midpipe back, straight through and out the little rotor emblem in the back - so I got rid of the duals, saved some weight, and have higher flow - best part - the shop made a custom muffler tip in the shape of a rotor to go out the rotary shaped hole they cut, so it looks like it belongs! With this, and my manual boost controller, I made 239 whp @ 7 psi
Finally, we used the GReddy injector harness and raised the boost to 8 psi. The shop said they didn't feel comfortable pushing it past 8 on the e-manage, much to my disappointment. Final result - 269.8 whp @ 8 psi.
Next step? AEM standalone when that comes out, and hopefully figure out how to open the ports WAY earlier, like as soon as the turbo spools up.
Old Oct 19, 2005 | 12:28 PM
cretinx's Avatar
Old Oct 19, 2005 | 12:31 PM
Moostafa29's Avatar
Storm Trooper
You're disappointed with 270whp at 8psi ??? Nice stuff though, post pics of the exhaust!
Old Oct 19, 2005 | 12:37 PM
zoom44's Avatar
im extremely disappointed in that number as well. maybe you took your footout of it? i mean point 2 from270- you must have lifted early
i keed i keed really iam a keeder:D
Old Oct 19, 2005 | 12:45 PM
NgoRX8's Avatar
I'm dissappointed they didn't boost it up to 14psi. :D
thats some great numbers right there already. Post some pics!
Old Oct 19, 2005 | 12:48 PM
cretinx's Avatar
I have a meet this Saturday, hopefully some people will take pics of the exhaust.
And yes, I need at least 300 whp to keep up with my friend's Supra and Z06.
I wanted 12 psi at least, which should hit 300 whp, but the shop said the e-Manage just isn't the tool to do it. I'm sure I COULD just raise the boost and pray - the car has already seen 16 psi with no ill effects (we forgot to tighten the boost controller when installing it!)
However, the guy told me he did the math and the stock injectors/pump aren't good for more than 10 psi safely.
Car is fun! About as fast as my RX-7 now.
Old Oct 19, 2005 | 12:59 PM
cretinx's Avatar
Oh . . . and just wondering (please don't yell at me and tell me to do a search)
what's the conventional wisdom in throwing a 50 shot in there?
Old Oct 19, 2005 | 01:32 PM
rkostolni's Avatar
I'm guessing post#2 is a dyno chart, but it doesn't seem to be showing up. Can anyone else see it?
Old Oct 19, 2005 | 01:35 PM
MadDog's Avatar
Consiglieri
When you said "just the GReddy kit", is that tuned, or untuned? You still running the emanage blue, right?
With such a large gain by going up only 2 psi, that makes it sound like you were running the stock map at 6psi. I am in the midst of tuning right now. I am aiming for 11.5AFR. I can already tell a huge difference in the power over the stock map. BTW for all you guys running the stock map, there is a REALLY LEAN spot in that map around 4k RPM. I'm talking AFRs of near 17 or so You guys need to watch your AFR's and tune it!
Old Oct 19, 2005 | 01:56 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Where are you located?
Old Oct 19, 2005 | 01:59 PM
cretinx's Avatar
A) 6 psi was tuned for a few hours
B) 7 psi I had the custom exhaust/midpipe and the original tune
C) 8 psi we decided to lean it out a lot and had about 2 hours tuning, plus injector harness added
D) Yes, the second post is SUPPOSED to be my dyno charts. It won't let me upload them, and they're too small on photobucket - anyone wanna host?
E) Located in Washington, DC
Old Oct 19, 2005 | 02:10 PM
dmp's Avatar
dmp
RX8 and a Truk....
www.njsr.org
Old Oct 19, 2005 | 02:28 PM
cretinx's Avatar
also - what are injector options for our car?
Old Oct 19, 2005 | 02:31 PM
Moostafa29's Avatar
Storm Trooper
Your dyno was showing up when you first posted. Then it disappeared.
Old Oct 19, 2005 | 02:40 PM
cretinx's Avatar
http://cretinx.tripod.com/STUFF/horsepower8psi.bmp
http://cretinx.tripod.com/STUFF/torque.bmp
try these, they won't post to the board.
Old Oct 19, 2005 | 02:50 PM
Moostafa29's Avatar
Storm Trooper
I get an error message: "This file is hosted by Tripod, a Lycos®Network Site, and is not available for download. Please check out Tripod's Help system for more information about Remote Loading and our Remote Loading policy. "
Old Oct 19, 2005 | 02:56 PM
Fanman's Avatar
Nice results. Also, if you have an HKS Certified Dealer in your area, take a look at the HKS PF Con V Pro. 10X the unit the EManage is.
For injector look at the high resistance 550cc units from RC Engineering for your primary 2's & maybe your secondaries.
I would push it to 10 psi first & see if your car has any problems. If it does than go for the injectors.
Old Oct 19, 2005 | 03:03 PM
rkostolni's Avatar
Cretinx, did Altered Atmosphere do your exhaust?
Old Oct 19, 2005 | 03:08 PM
Armaant's Avatar
Armaan
Crentinx could you post a pic of your exhaust...also if your really dissapointed with your car you can trade me for my stock 8
Old Oct 19, 2005 | 03:23 PM
cretinx's Avatar
Ok, a few more answers
from what I could understand, the e-manage won't allow us to pull fuel in certain parts because the map just has a big 0 for the little block, but in reality we need to pull fuel - and with injectors, we would DEFINATELY have to pull fuel, so I've gotta wait for a standalone.
I'm sorry about the charts - I'll work on getting them up.
I don't have pictures of the exhaust, I don't have a digital camera to take pictures of the exhaust - maybe Saturday at my meet someone can take some shots for me
I will NEVER let Altered Atmosphere touch my car again, or give them business. They are a bunch of scam artists and bastards. You will find 90% of people who have dealt with Altered will say the same thing.
I went to Agile Auto in Cockeysville, Maryland, and they were FANTASTIC. They also did my friend's supercharged Miata which was a blast, and when I was there they had a twin-turbo NSX, and their SEMA winning WRX - both very cool cars to look at.
I'll look into the f con - what is the benefit of it over the e-manage? I'm thinking I won't change ECUs until there's one that allows electronic control of the ports, so I can have all ports open when the turbo kicks in.
Old Oct 19, 2005 | 03:49 PM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
As far as I know(per Jeff aka MazdaManiac) you can open the ports up with the emanage. I would attempt to contact him, as he seems to be very knowledgable in regards to these kinds of things. I also recall RG mentioning that the megasquirt is capable(look for his and Brillo's thread about the megasquirt project). Have you looked at the Mazsport unit as well? Your results are pretty sweet, good luck with the rest of your project.
Old Oct 19, 2005 | 04:09 PM
OfficerFarva's Avatar
Hey dude, nice nice resuts. I got the greddy kit to and i should be up and running tonight or tomorrow. Hopefully I'll have sum good luck like urself .
Old Oct 19, 2005 | 05:09 PM
rkostolni's Avatar
If you want to open the ports up with the emanage I posted a schematic of a circuit that would do that awhile ago. Its pretty simple to build and I could help you through it. I would love to see what kind of gains it would produce.
Old Oct 19, 2005 | 05:13 PM
rkostolni's Avatar
How does 270whp in the 8 feel by the way? I live pretty close to you in northern VA, any chance of getting a ride in that thing? In return you can check out the Interceptor computer when it eventually arrives since you are looking at a new stand alone.
Old Oct 19, 2005 | 05:54 PM
cretinx's Avatar
It feels pretty good actually. About as fast as my old GT3540R RX-7 @ 11 psi.
Sure I'll give you a ride, and you can tell me more about opening these ports earlier.
