is it a big poroblem if u using the wrong engine oil?
Old Oct 19, 2005 | 01:26 AM
fcmountain's Avatar
Aaron
i bought my rx8 in the use car dealer, and they were using the (Not mineral) engine oil becox at that time i don't know i have to use the mineral engine oil~and after i drive the car 2 months the problem was happen, the rev goes unstable after the engine is warm, and sometimes its very hard to start up the engine and it takes 3 or 4 times . and i wonder will that affect the performance and the engine still realiable???
Old Oct 19, 2005 | 05:59 AM
Go48's Avatar
The problems you are describing are most likely NOT the direct result of the type of oil you are using. You will need to determine the cause of the erratic engine rpm and hard starts. It could be nothing more than fouled spark plugs, but it could be something else entirely like low engine compression. Take the car to a competent mechanic that knows rotary engines and have it checked out. Good luck!
Old Oct 19, 2005 | 07:19 AM
fcmountain's Avatar
Aaron
o really ???? thank you for your opinion~
Old Oct 19, 2005 | 12:39 PM
Go48's Avatar
Sure. Let us know what you find out.
Old Oct 20, 2005 | 06:38 AM
fcmountain's Avatar
Aaron
can u please tell me which engine oil is suitable for rx8?
Old Oct 20, 2005 | 07:20 AM
Mugatu's Avatar
Even My Dog Searches
5W-20
as per the MANUAL
Old Oct 20, 2005 | 07:21 AM
Jaguar_MBA's Avatar
The manual says 5W-20 should be used. I have heard of some dealerships putting in 5W-30...probably the oil change guy that does not know any better.
Read this thread:
https://www.rx8club.com/series-i-tech-garage-22/rotarygods-rotary-oil-tech-blog-69805/
Old Oct 20, 2005 | 09:54 AM
ZoomZoomH's Avatar
Mulligan User
he's in New Zealand, the manual may not specify 5w20....
fcmountain, please check into YOUR owner's manual for oil specification for NZ....
Old Oct 20, 2005 | 04:08 PM
Jackallll's Avatar
128 Mazda in Massachusetts put 5w30 in mine and they didn't think it was a problem. The car seemed to run fine. I've put 5w20 in ever since though
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
RotaryRider
Jul 20, 2015 07:05 AM
