Door Panel Mounting Question
Old Oct 18, 2005 | 06:18 AM
crewshell's Avatar
I have found a cool little rotating and tilting arm that I would like to mount on my door panel so that I can then mount my treo 650 on it .. To mount it I would use a combination of a single screw and adhesive .. The mounting plate is a circle with a 1 inch diameter .. I would like to mount it roughly an inch infront of the door handle .. however I know the light that shines on the window controls is in that general area.... Any tips? Suggestions? On how to mount this bracket there?
Old Oct 18, 2005 | 08:12 AM
jenkins-crew's Avatar
I would remove the panel to see what is back there in that location. Just to make sure it is solid where you put it and doesn't interfere with any wiring. I would use a combo of 3M adhesive tape and small nut and bolt with washer and lock-washer.
Old Oct 18, 2005 | 08:14 AM
Any pics of the arm? Then installed pics.
Old Oct 18, 2005 | 11:11 PM
crewshell's Avatar
i'll try to get some up this week... I also got my vclear corners in soo you KNOW i'm busy : )
rotarywanker
Dec 8, 2022 05:56 PM
Warrior777
Jun 24, 2019 04:47 PM
projectr13b
Mar 1, 2019 09:00 AM
blkswan
West RX-8 Forum
Oct 24, 2016 11:34 AM
Majictoast
Jul 18, 2015 06:45 PM
