RX8 Cruise control Max Speed only at 102Km/h
Old Oct 14, 2005 | 11:08 AM
anthger's Avatar
Hello,
I have a Japan specs RX8 and last week i install the cruise control switch.
After that the cruise control was enabled in the RX8.
I have one problem.
The maximum speed that the Cruise Control can be set is 102Km/h
Do anyone knows how to fix this?
I take the car and install the latest firmware and then the cruise control stop to work so a went back to the privius firmware virsion.
Regards,
Antonis Georgiou
Old Oct 16, 2005 | 11:01 AM
MintyFresh's Avatar
maybe id you remove the top speed limiter it will also fix the limiter on the cruise control
Old Oct 17, 2005 | 09:07 AM
anthger's Avatar
Well i already did that but still nothing!!!! cant go over 102km/h!!!
Maybe there is any ECU control manager that we can buy and use it to tweak the RX8 and the same time some fitures like the cruise control?
Old Mar 21, 2016 | 06:26 AM
pilotedge's Avatar
I haven't found any other threads on this topic.. Has anyone found a way to change this cruise control limit?
Originally Posted by anthger
Hello,
I have one problem.
Regards,
Antonis Georgiou
Old Apr 20, 2025 | 09:18 PM
Duot5250's Avatar
Cruise control limits.....
I have same problem on my 6at with Japan spec
Anyone know how to fix this?....
New progress update:
After replacing the ECU with an N3M6 model, I can now enable cruise control at speeds above 100 km/h.
However, I have another new problem: I don't know which ABS unit should be paired with the N3M6 ECU... If anyone knows, I would appreciate it if you could kindly share the information.
B-Ron
Dec 13, 2009 01:22 AM
hawkwind
RX-8 Show and Shine
Jan 29, 2009 04:57 PM
skhmund
Aug 18, 2006 11:34 PM
Emsdad
17
Nov 1, 2004 07:28 PM
rotarenvy
Australia/New Zealand Forum
Apr 5, 2004 06:12 AM
