bad motor mount in my rx-8
Old Oct 14, 2005 | 12:07 AM
typej's Avatar
Unhappy bad motor mount in my rx-8
My RX-8 was diagnosed with bad motor mount and is in the shop now. I started noticing vibration when in car is stopped and it got worse progressivly. It was like a bee hive today before I took it in for service. Hopefully I will have it back by tomorrow.
I was wondering if anyone had similar problem with their rx-8? I thought RX-8 would be more reliable since it was built in japan, but that must be a thing of a past.
Well, other than that, mazda dealer provided awesome service and also are paying for the rental car. Thank god I still have a warranty... this made me wonder if I should have purchased extended warranty.
:p
Old Oct 14, 2005 | 12:11 AM
Gomez's Avatar
Shifty Bastard.
It's not a common fault, but it has happened in the past. I can recall two or three others that have had mounts fail. A newly designed mount was fitted.....one that had a shield to protect it from radiant engine bay heat.
When was your car manufactured?
Old Oct 14, 2005 | 12:24 AM
typej's Avatar
mine is 2004 model and I think it was purchased on december of 2004 by first owner? but that doesn't really tell when it was manufactured... Car could have been sitting on a lot for a long time.
Hopefully they will install newly designed motor mounts on mine. I can't wait to have silky smooth rx-8 back. I am already tired of SUV they rented me out.
Old Oct 14, 2005 | 12:27 AM
Gomez's Avatar
Shifty Bastard.
Originally Posted by typej
.....Hopefully they will install newly designed motor mounts on mine...
They will. The older style will have been discontinued.
Old Oct 14, 2005 | 12:30 AM
Gomez's Avatar
Shifty Bastard.
Can we get a Mod to move this thread into Issues and Problems??
Ta.
Old Oct 14, 2005 | 01:12 AM
adrian-1's Avatar
Ex- member.
Lots of others have had this problem. It's the passenger side motor mount, correct? Many believe it's due to the exhaust manifold heat that makes them crack.
Link to thread here.
It was also mentioned that this problem was one step below being a TSB.
Old Oct 14, 2005 | 01:17 AM
Macius8's Avatar
Hey I may be having this little problem. I have a small vibration when the car is at idle and when the engine is completely warmed up. It usually happens when im stopped at a stop light. Could this be the motor mount? I was going to take it to the dealer for the next oil change and have them check it out. What you guys think?
Old Oct 14, 2005 | 01:20 AM
Macius8's Avatar
OK never mind i read the link adrian gave, thanks. Crap my first problem with the 8 at 24500 miles.
rotorocks
47
May 11, 2016 03:23 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
Rx808BI
Aug 9, 2015 10:06 AM
rags1231
Jul 30, 2015 08:57 AM
harithac
Jul 25, 2015 04:21 PM
