Why don't they use a CVT for the Autos?
Old Oct 13, 2005 | 05:18 PM
The RX-8's Avatar
I was just wondering why they would never get into using a CVT transmission on the Automatic 8... That way, almost all the energy of the 6 port engine can be harnessed and the 9000 RPM redline would still be there. They have one on the Murano and the Vue and some Subaru had one a while back. The Vue and Murano both produce more HP than the 8, so the HP limitations shouldn't appear to be there, and consider the benefits of a CVT:
1. Higher MPG
2. Less gas emissions
3. Better performance
4. Greater efficiency
Those seem to be issues inherant in the rotary engine, so I would assume that a CVT would be the optimal transmission to pair with it. There will be those that would still want manual, but for those who are buying an automatic, they might as well use a CVT! What am I missing that makes Mazda overlook this?
Old Oct 13, 2005 | 05:21 PM
Glyphon's Avatar
脾臓が痛みました
i would imagine that it has something to do with reliability at 9k rpm. while the other motors may have more power, they don't spin nearly as fast.
Old Oct 13, 2005 | 05:44 PM
zoom44's Avatar
is there even a cvt in the ford family parts bin for them to even look at?
Old Oct 13, 2005 | 06:01 PM
beachdog's Avatar
Ford offers a cvt in the Freestyle crossover suv and I believe that they offer it in the 500 too.
Generally speaking, cvt trans don't seem to find there way into performance cars mostly economy cars. My niece had a Honda civic cvt and it was a pos. Trans was replaced at least 5 times under warranty. If Honda can't get it right not sure how good a Ford unit will be.
Old Oct 13, 2005 | 06:06 PM
brillo's Avatar
Go Texas Longhorns!
They would likely have to limit the cvt to 7500rpm or so, like the conventional auto, as I'm not sure how they handle high rpm engines.
audi could only use them for FWD applications due to packaging issues, so I'm not sure if they have a unit that would fit a RWD application. In fact, I can't think of a single RWD car with a CVT. Nissan Murano's can be AWD and have a cvt, but they are much bigger cars/vehicles. DSG is what we really want.
Old Oct 13, 2005 | 06:11 PM
The RX-8's Avatar
Yes, the 500 has an Electronically controlled, continuously variable transmission its automatic transmission option only on the AWD platform however. I find that odd... Additionally, it's CVT has a 2.47 through 0.41 gear ratio while the current AT on the 8 has a 2.785 through 0.694 ratio and the MT has a 3.76 through 0.843 ratio. I'm just floating the idea as I really can't find any cons to it.
Old Oct 13, 2005 | 06:34 PM
zoom44's Avatar
you guys should read thru the cvt thread from 2 years ago https://www.rx8club.com/showthread.p...&highlight=cvt and just quote teh posts in that htread that say what you were thinking of posting here :p
really give it a read good info there that i almost forgot about concerning mazda's cvt and some other interesting info about aisin on the third page
Old Oct 13, 2005 | 06:44 PM
agoodcave's Avatar
My sister's ex-boyfriend is a project manager at Ford. According to him, Ford has had CVT's developed for several years. In fact, several of the new tranny's are CVT's. Unfortunately, buyers keep bringing the cars back to the dealer because they think something is wrong since they "won't shift". Ford has actual "wired in" shift points to make it feel like a conventional tranny.
He managed the Escape hybrid and the Zero emission Focus.
Mike
Old Oct 13, 2005 | 07:06 PM
NomisR's Avatar
Isn't that the beauty of the CVTs?
Old Oct 13, 2005 | 07:08 PM
oreo's Avatar
Would there be weight ishues with the cvt. Also price might be a factor to consider.
Old Oct 13, 2005 | 08:24 PM
Ericok's Avatar
Rotary Wanker
My dad's Ford 500 has CVT and it doesn't have any "wired in shift points". I admit that it's kind of weird driving it without any shift points to reference to but it is smooth. I thought the problem with the RX-8's automatic was that it was the torque converter, not the rest of the transmission, that couldn't stand the high RPM. Ford's CVT still uses a torque converter so that wouldn't help the RX-8.
Old Oct 13, 2005 | 10:16 PM
The RX-8's Avatar
I was under the impression that CVT does not *require* a torque converter, however some do use them. For instance, I found this article:
http://www.thecarconnection.com/index.asp?article=5029
Which specifically states this:
Originally Posted by The Article
Torque converters are convenient for drivers, but are inherently inefficient because of the slippage, and this inefficiency makes itself felt in gas mileage.
In place of the torque converter, the Torotrak has a system of two clutches in which the drive is transmitted by variators.
I was just floating the idea because it seemed as if this transmission excelled at things which the rotary is lacking, so I thought it would have made sense to pair them.
ON EDIT: I also found that the Honda Insight's CVT also does not have a torque converter...
http://www.insightcentral.net/encyclopedia/encvt.html
I also find it interesting to note that they mentioned this:
Gear Ratio is controlled by a pre-set 3D map with car speed, throttle position, and ideal engine rpm as its 3 axis. The difference between current and ideal engine rpm on the chart is continuously fed back to the ECU. Using linear solenoids, the four-way valves controlling pulley width are activated.
In order to prove useful in all situations, there are three 3D maps the user can select from. In D(rive) mode, the upper power band is avoided, resulting in excellent fuel economy. In S(port) mode, the user can redline the engine.
By using the 3D map control pattern, the Multimatic has the ability to stay in the same power band if/when needed. An example of this is the ability to remain in the high-rpm power band from a standstill to high speed. Because of this, full-throttle acceleration is equivalent to that of a manual transmission. In addition, when traveling at high speeds, because of its ability to infinitely adjust gear ratios, the Multimatic has more passing ability than not only the manual transmission but the conventional automatic transmission using torque converters. With these advantages and the ability to still "shift" to "L" to use the engine brake, there is nothing but advantages.
This ability to do that on the CVT would allow for the paddle shifters to still function, but it could even function as a gear ratio chooser! THEY COULD DISPLAY THE GEAR RATIO CURRENTLY IN USE AND IF YOU PUSH THE PADDLE SHIFTER, IT CAN, IN REAL TIME DISPLAY THE GEAR RATIO GOING UP OR DOWN! Or they could oversimplify it by giving you 4, 5, 10, 17, 2300, 10000000, 337582e10382 different preset gears to shift through and allow you to redline at each. That would be a cool feature, and allow you to easily redline whenever you wanted, allowing you to see the true benefit of the rotary engine and its seemingly limitless RPM, and at the same time, allow you to switch into Economode, allowing you to get ~25 MPG in the city... That would be outstanding IMO. The only question here is, since the CVT lacks a torque converter, would it be able to be implemented in the RX-8 or are there other issues that prevent it from happening?
Oh and also, for those who talk about semantics, I would like to say that I mean an IVT, not a CVT, since IVT includes neutral and reverse, which a CVT DOES NOT.
Also, I find it funny that the smoothest engine on the road would be paired with the smoothest transmission available. Would that not create the SMOOTHEST CAR TO DRIVE EVER?
Old Oct 14, 2005 | 12:24 AM
Emperor's Avatar
aka Spectre
I used to drive a CVT civic. From my understanding, the CVT cannot handle too much power without reliability issues.
In short, the CVT is run with a steel belt on 2 pulleys. Its the steel belt that will give way under high loads.
Yup, the CVT is the best transmission ever.
Old Oct 14, 2005 | 12:44 AM
typej's Avatar
Um I guess I can start claiming which is the best transmission in the world here, so
DSG is the best transmission ever!
on those new VW and Audi cars.
Boy I want it instead of Shiftronic or whatever on my car...
Old Oct 14, 2005 | 11:54 AM
Glyphon's Avatar
脾臓が痛みました
the dsg is an insanely-freaky smooth transmission. the only way you can really tell its changing gears is if you look at the display on the dash to see it change.
Old Oct 14, 2005 | 12:43 PM
RevTo9K's Avatar
1.3L is enough 4 anybody
For a long time, belts strong enough to handle high power and torque were too expensive to manufacture. Nissan's CVT handles 245 HP and 245 lb-ft in the Murano. However, the Murano's only a couple years old. Long-term reliability issues wouldn't be showing up yet.
One other CVT issue that I read about is that the tranny ends up being relatively tall, which wouldn't work well in a car like the RX-8.
Old Oct 14, 2005 | 03:09 PM
The RX-8's Avatar
And why not? The RX-8's center console extends through the back, so it would not be unreasonable to get an extra inch or two out of it...
Also, the DSG should be LESS EFFICIENT than the IVT because the DSG still relies on preset gear ratios, not the infinite ratios that an IVT provides... That means that you cannot achieve optimum efficiency for each and every rpm level.
Old Oct 14, 2005 | 03:42 PM
zoom44's Avatar
why dont people read the info in the link i provided? it doesnt have to be any taller at all.
Old Oct 14, 2005 | 04:02 PM
hedgecore's Avatar
Health Supplement User
Are there and high performance CVT's out there? CVT's are great, but they don't seem suitible for performance cars...yet.
In fact, the prius CVT is designed for POOREST performance(a Toroidal CVT with a few engineering variations to suit the goals of the car)...i remember reading through the eng docs for it some time back and related it to something close to always driving in a gear that is as high as possible while still being able to move the car forward...a clever trick for good gas miliage, but now how i intend to drive my 8.
BTW, is that Ford 500 using a Toroidal CVT?
Old Oct 14, 2005 | 05:29 PM
zoom44's Avatar
why dont people read the info in the link i provided? .
Old Oct 14, 2005 | 05:47 PM
Glyphon's Avatar
脾臓が痛みました
they have to start reading more than the subject line of the topic before replying for that to happen
Old Oct 15, 2005 | 10:28 PM
hedgecore's Avatar
That thread is a bit far from comprehensive on the topic of CVT.
It's also pretty dated.
gwailo
May 14, 2024 06:57 AM
Cookingislife1226
Mar 20, 2016 09:51 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
