Botched Fuel Tank Recall
Old Oct 11, 2005 | 05:22 PM
fast_rx's Avatar
Hi all,
Since my fuel tank/heat shield recall work was done, I've developed some problems.
The first thing I noticed was a very persistent cricked chirp over any little bump. While trying to find the chirp, I realized that it won't happen if I have any tension on the parking brake handle - so I think that may have actually been caused by the recall since they have to move the brake cable aside. But this isn't the big problem...
The BIG problem is that the car hesitates, bucks, and eventually starts to die on acceleration if I get below 1/8 of a tank. The lower it get's the worse it is. It's just like I'm turning the car off as I'm driving if I press on the gas. Initially, I thought it could be some bad gas. But I've gone through a lot gas and the problem comes right back when the 1/8 level is hit. If I put in a couple of gallons, it magically goes away... No check engine light or anything, so I'm doubting that there is any code being stored.
I really would prefer taking the car back in with some ideas of what could be the problem, so any speculation or ideas would be appreciated.
Old Oct 11, 2005 | 05:34 PM
Detrich's Avatar
幹他媽!
You didn't mention where you're located in or which dealer you took your car into Fast...
Old Oct 11, 2005 | 05:40 PM
fast_rx's Avatar
I'm in Huntsville, AL... But I'd rather find out what could have gone wrong instead of pointing fingers.
Old Oct 11, 2005 | 06:27 PM
Aseras's Avatar
did you even try bitching at the dealer yet?
Old Oct 12, 2005 | 08:30 AM
KYLiquid's Avatar
Oil Injection
sounds like they didnt bolt the tank in all the way, or its not sitting level/correct.
Old Oct 12, 2005 | 12:36 PM
fast_rx's Avatar
Aseras, I have talked to the dealer... It's just going to be a while before I'll be able to get it in to have it looked at. I'm taking the car in Monday, so I'll post what I find out.
Anyways, they say it sounds like water in the gas, but I just don't understand why it would only pull the water in at the 1/8th of a tank level since the water is going to be on the bottom the whole time. If there's something wrong with that logic, please tell me...
BTW, I thought maybe my fuel gauge was wrong, but it only takes 11 gal to fill it back up.
Old Oct 12, 2005 | 01:43 PM
Aseras's Avatar
I'm betting they kinked the fuel line.... Fuel pump is probably able to force gas through until the volume is low enough that it pulls in air from slosh and then can't maintain fuel pressure.
Old Oct 12, 2005 | 01:48 PM
zoom44's Avatar
or the system is unable to pull gas from one saddle bag to the other side when it gets low causing the starvation
theblinkof
Oct 4, 2023 05:24 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
