17" wheels specs?
Old Oct 9, 2005 | 10:30 PM
humagin's Avatar
17" wheels specs?
I stopped my choice on the Hankook W300 Ice Bear 225/50R17 (from what I have read, it is the best ratio: value/winter performance).
My question:
Will any of the 17" wheels that have these specs will fit on the Rx8 meaning that they will all clear the calipers or should I be carefull when ordering them via the internet due to the fact that they might not fit even if they have these specs:
17 x 7, 5x114.3, 38 to 45 offset
Old Oct 9, 2005 | 10:32 PM
truemagellen's Avatar
Attracts tree branches
best value would defintely be buying stock 18s used opn the forum then get a set of slightly used Blizzak LM-20s or find em cheap online
Old Oct 9, 2005 | 10:34 PM
humagin's Avatar
Thanks, but a need advise on the rims and not on the best value
Old Oct 9, 2005 | 10:39 PM
ECHO1's Avatar
try searching, i posted this a while ago in a couple different threads
http://marksink.com/tire_wheel_offset/offset.html
Old Oct 9, 2005 | 10:42 PM
humagin's Avatar
This is what I get:
The clearance from stut housing to the inside of the wheel will be 25mm MORE
The outside edge of the wheel will RETRACT in towards the body by 1mm
How can I be sure that the 17" rims will clear the calipers (brakes) with these numbers?
Thanks.
Old Oct 9, 2005 | 11:26 PM
ECHO1's Avatar
hmmm, good question. throughout all my searching for wheels, the smallest diam. i remember fitting the 8 is 7.5 what wheels are you looking at?
Old Oct 9, 2005 | 11:53 PM
humagin's Avatar
I am looking for something like the Drag DR-11 Silver:
Size: 17 x 7
Pattern A: 5x100
Pattern B: 5x114.3
OffSet: 40
Colour: Silver
Old Oct 10, 2005 | 07:34 AM
expo1's Avatar
He's as bad as Can
Doing a search on this board I didn’t find another owner with Drag DR-11. Tire Rack also does carry that rim. If you cannot see the rim in person the safest thing to do is buy ONE rim provided the retailer would take back a un-mounted rim and test fit it on the front without the tire. If it clears the brakes buy the other three, if not you’re only out shipping one rim back.
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
Quiggs321
Sep 30, 2015 05:34 PM
GranTouTou
Sep 30, 2015 06:11 AM
