Auto Dim Mirror vs. rear wing
Old Oct 5, 2005 | 08:56 PM
DarkBrew's Avatar
Extraordinary Engineering
I know this is a topic from the past but... I am a new owner so I read the previous posts but did not find an answer.
Is there a way to solve the problem of the sensor being blocked by the shadow of the rear wing? (besides removing the wing)
Is there someone out there with a clever solution? I like the Homelink buttons for the garage but this auto dim system drives me crazy.
Old Oct 5, 2005 | 10:06 PM
RedRexNJ's Avatar
I was toying about with the idea of opening up the mirror and removing the sensor from the PCB inside. Then I was going to run some wiring from the mirror, through the interior of the car along the upper portion of the doors, to the rear window. There I would place the sensor in a small pod or housing at the upper center of the window, and connect it to the wiring running from the mirror. It should work, and it would solve the problem of the wing shadow blocking the sensor sometimes.
Just haven't gotten around to doing it yet...
Old Oct 6, 2005 | 08:13 AM
DarkBrew's Avatar
I was thinking of a similar mod.
Maybe you can post pictures if you get around to doing this mod.
Old Oct 6, 2005 | 08:51 AM
dazygirl415's Avatar
Odd, I had the OEM wing and now the MS wing and I've never had a problem w/the sensor.
Old Oct 6, 2005 | 10:45 AM
truemagellen's Avatar
Attracts tree branches
why don't you guys just press the button and turn off the auto dim???
Old Oct 6, 2005 | 11:45 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
Cuz they haven't read the Owner's Manual and found the switch.
Old Oct 6, 2005 | 12:12 PM
hmmm you mean the two huge buttons on the unit?
Old Oct 6, 2005 | 02:16 PM
TooBIG's Avatar
Same.
I had the factory wing. Now the MS wing.
Mirror dim works the same/correct.
-B
Old Oct 6, 2005 | 02:26 PM
KYLiquid's Avatar
Oil Injection
you can turn it off so it wont dim, but I think their problem is that the wing is blocking the light from getting to the mirror, so it wont dim down at night.
Old Oct 6, 2005 | 03:18 PM
RedRexNJ's Avatar
Exactly. And why would we want to turn off the auto dim? Why have it in the first place? What we're trying to do is get it to work like it's supposed to, without interference from the rear wing. It's very annoying to have the mirror get lighter and darker every 10 seconds because the sensor isn't "seeing" the a-hole's highbeams behind me cause my spoiler is in the way.
Old Oct 6, 2005 | 06:05 PM
aRX7-7-8's Avatar
RedZoomZoom
Change mirror location and add a filter
I had the same problem: the auto-dimming sensor wasn't reacting when the lights were blocked by my rear spoiler. I did two things to improve the situation.
First, there is a lot of freedom in location of the mirror because there are two pivot points in the mounting arm; I found that moving the mirror to its highest location gave the sensor more visibility to incoming light from the rear.
Second, there is a small sensor on the forward-facing side of the mirror that adjusts for ambient light, to prevent the auto-dimming from occuring in daylight. I added a few layers of semi-transparent tape over that sensor, which shifted the sensitivity of the dimming.
I hope others find these steps useful.
Old Oct 7, 2005 | 07:59 PM
DarkBrew's Avatar
I raised the mirror as described and taped some metalized mylar over the front sensor (from an ESD bag). The auto dim is working better now.
Thanks for the simple solution...
The only issue now is the tape on my mirror.
Old Oct 25, 2005 | 12:41 PM
nokiafan88's Avatar
Hey guys, I was just checking...i have a base model RX8 and i was wondering if its possible to mount the auto dim mirror ? The stock mirror sucks because i dont have the auto dim feature and wondering if you guys know if theres any wires that come out of your guys mirror ?
Old Oct 29, 2005 | 11:11 AM
Shinka13's Avatar
I don't have a rear wing, but I know from experience, 20% window tint will keep your mirror from dimming too. There is never enough light getting past my rear window for the mirror to recongnize it. Just makes it a little harder to back up at night.
Old Oct 29, 2005 | 08:07 PM
DarkBrew's Avatar
There is a small electrical connector with four wires for the auto dim mirror.
RXFEVER
Sep 11, 2016 02:51 PM
nowakm99
Oct 9, 2015 07:10 AM
Rupanrx
Sep 4, 2015 06:44 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
