how to jack up the cars onto the jack stands? HELP HELP!!!
Old Sep 27, 2005 | 10:52 PM
JordanC's Avatar
Can anyone tell me which part of the bottom .. the chasis that is safe for jacking and which part shall i put the jack stand at... it be very helpful if pic is included... thanks!!! RX8Club.com's members RULEZZz
Old Sep 27, 2005 | 10:58 PM
staticlag's Avatar
The Professor
Under the rear differential for the rear, and under the front crossmember for the front.
For the jackstands, you can just use the factory jack points outlined in the manual.
Old Sep 27, 2005 | 10:59 PM
Nemesis8's Avatar
Bigus Rotus
Drive the car up onto 2x4's first
Old Sep 27, 2005 | 11:13 PM
staticlag's Avatar
The Professor
Yeah, if you don't have a really nice jack, this definetly helps.
Old Sep 28, 2005 | 05:36 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
2x4's? Hey, thats a great idea! Hear I am under the front of the car jacking it up with a screwdriver in the jack 0.0783 inches for every downstroke, banging knuckles at every stroke. Thanks!
Old Sep 28, 2005 | 05:39 AM
Go48's Avatar
Static is correct. It's spelled out in the manual. Problem is getting the floor jack under the car and still being able to pump it up. You will have a difficult time finding a floor jack that will slide under the car without first lifting the car up somehow.
I built some ramps out of 2x10's to get the car up high enough to allow use of a floor jack. I also sometimes jack up the side of the car with another jack at the points indicated in the manual and then slide the floor jack under the front or rear jacking points. Like static says, you can use the side jacking points for jack stands or just pick out a good solid section of the "frame" rails.
Finally, do a search of the forum. As I recall, someone in the past posted pics of their suggested jack stand points.
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
RX7.9
Jul 20, 2015 12:01 PM
