Spark Plug Cleaner.
Old Sep 26, 2005 | 08:19 AM
expo1's Avatar
He's as bad as Can
Spark Plug Cleaner.
Based on the price of a set of spark plugs for our 8’s I was thinking about getting a spark plug cleaner like the one in the pic and a second set of plugs. The plan would be to alternate sets of plugs and clean them maybe 2-3 times before I would get rid of them. My questions are can our plugs be cleaned and are the 12v sparkplug cleaners any better / worse than the ones that run off an air compressor.
Old Sep 26, 2005 | 08:30 AM
JonsToy's Avatar
Registered Rep
I miss the good, old days when all you needed was some fine-grit sandpaper and a gap tool!
Old Sep 26, 2005 | 10:04 AM
KYLiquid's Avatar
Oil Injection
lol that looks like a garbage disposal with jumper cables coming out of it.
I have no experience with cleaning spark plugs, i just toss them and stick in new ones ever year.
Old Sep 26, 2005 | 11:12 AM
Nubo's Avatar
Lubricious
I used to have an el-cheapo one. I'm not sure it ever did anything useful. Some dust from the "grit" would stick to the surfaces, causing them to look lighter, and therefore "cleaned". I eventually stopped bothering with it.
One thing you do want to avoid is scratches and nicks in the porcelain insulator "nose". These can develop into conduction paths ("carbon tracks"). Once a conduction path is etched into the porcelain the plug is done for. The more powerful the "cleaner" is (or the more aggressive the grit) the more I'd worry about this. From what I've learned, unless the plug is obviously fouled you're better off leaving it alone. If the engine is running properly the plug should remain serviceable without your assistance until the electrode wears past the limits (our plugs aren't adjustable for "gap"). If you have an obviously fouled plug the first issue is figuring out what problem is causing it. Once you have that issue squared you can scrape the goop out with a soft bit of wood, which won't scratch the insulator. It might be ok and normal engine operation will bring it back into a "normal" state as long as "carbon tracks" haven't already been etched into the porcelain from misfires.
I've read plenty of posts that suggest spirited high-rpm runs are the best "tool" for clearing the plugs and based upon recent experience I'd tend to agree. A few weeks ago I had such a drive -- about 2 hours worth of "spirited" driving. Afterwards I noticed a definite improvement in smoothness, especially at low rpm "stop and go" traffic. This was before taking the car in for the recall, which seemed to improve the low-end even more.
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
