View Full Version : Transverse mounting a 13B/Renesis
Psylence
09-24-2005, 02:58 PM
Just like the thread title says.... is it possible? I've got a potential mid engine project kicking around here... and despite how "sacreligious" it might be, I'd love to use a rotary engine in it. Clearly, the standard transmission will not work.. anyone have any thoughts or ideas?
Xyntax
09-24-2005, 03:07 PM
I saw a pic of a CRX with a 13B-REW or was it 12A engine in it. I'll post it when I find it again.
TeamRX8
09-24-2005, 06:16 PM
the biggest problem is that the rotary engine has a high output centerline as compared to a piston engine, so it's just a matter of whether you can get it low enough
Psylence
09-25-2005, 05:33 PM
Good call TeamRX8, I hadn't even thought about that.
I'll bet the midengine layout would pose a problem for keeping the engine cool as well.. :(
Shame, a turbo rotary powered Stratos (http://www.superstratos.com/corse.html) is pretty much my dream!
epitrochoid
09-25-2005, 05:35 PM
someone figure this out so i can tear that terrible taurus motor out of my nobel m14 and put a wankle in there
ps1726
09-27-2005, 11:27 AM
Had a 86 Fiero lying around , will like to do the swap, but will need an engine
transmission adapter, anybody knows?
bgreene
09-27-2005, 08:59 PM
Does it need to be a transverse mount? Rotaries are so compact, you might be able to fit it onto a transaxle in an axial mount position (if the transaxle will take such an interface, that is.....).
the whole works may need to be angled (get ready to rework the oil sump....) because of the height of the shaft, unless the coolant flow will work with the engine laying on its side.
therm8
09-27-2005, 09:15 PM
Not necessarily. As I was researching a home built mid-engine project myself, I of course considered the Renesis. Mounting the radiator up front would allow for proper airflow, with the added benefit of considerably more volume. My biggest concern was adequate exhaust muffling for street use. I was looking at using a 4port motor in an 1800lb vehicle as 240hp would be more hp/weight than I'd really need. But it would be quite fun.
bureau13
09-27-2005, 10:58 PM
Somebody had a rotary powered Lotus Europa (may have been a Europa replica) at one point, so I know it CAN be done.
jds
gh0st
09-28-2005, 11:52 AM
all you need is a custom tranny or a custom adapter plate.
therm8, any chance that you are talking about the attack?
denward
therm8
09-28-2005, 01:26 PM
denward
no, too expensive, and they don't make it in kit form any longer. I was going to go from the ground up using an MR2 turbo as a doner for the uprights, random pieces parts, and engine/tranny. The rotary was just a thought really. The very bad exhaust tone when not properly muffled turns me off to it.
Xyntax
09-28-2005, 03:31 PM
I found one at the barotary. It's a FWD wagon:
http://barotary.com/bbs/viewtopic.php?t=123
