center radio knob removal
Old Sep 22, 2005 | 06:01 PM
TIM-8's Avatar
center radio **** removal
I have gotten a brushed aluminum rotor shaped radio **** and cant seem to get the factory **** off. Is there a trick to it? Thanks Tim
Old Sep 22, 2005 | 06:43 PM
psbjames1970's Avatar
Come Rain, come shine :-D
Me tinks that the face place needs to come out ...
Just a hunch though.
Old Sep 22, 2005 | 08:47 PM
mazradiodoc's Avatar
If you remove the lower module blank under the ****, it will make it easier to remove (easier not easy) The **** is on there tight.
Also rotate the **** as you pull so your not just working one side of it up the shaft.
Old Oct 16, 2005 | 03:17 AM
BoosTED's Avatar
Mine pulled straight out no need to remove the faceplate.
It was on there very securely though. I don't see a benefit to rotating the **** while pulling it off. I think it is better for the head unit to pull straight out.
I replaced with the Petite Racing Radio ****.
Old Oct 17, 2005 | 02:43 AM
truemagellen's Avatar
Attracts tree branches
the hardest mod we've done lately eh :p!
yes I concur...it appears they put a bit of adhesive on the ****...very very light that you just need to loosen...don't bend left and right you may never have a straight **** again...and the girls won't like that
as for the ****...I'm painting base part that is the non-rotor non-rx-8 sticker center, black...it should accentuate the rotor and reduce the ***** over abundance of bling bling
btw anyone have access to more of those stickers in the middle mine is not on perfectly straight
Old Mar 6, 2007 | 10:26 AM
Dremd911's Avatar
Dre's 8 "I started Late"
does anyone know if the mazda6 ***** that have the + and - lit ***** for a/c and heat etc....fit on the rx8 *****...i was reall jealous to see my freinds 6 lit up all nice and my shitty ***** dont light up or have the illumination under or spaces for it.....also another big question are the lights in automatics suppose to light up or do they just expect you to look at the speed cluster to see if your in the right gear???
Old Mar 7, 2007 | 06:27 AM
highspun's Avatar
Tim
Could you tell me where you got the ****, that sounds like a very slick mod.
Old Mar 7, 2007 | 07:35 AM
foo77's Avatar
4th batch : Apr 03'
i'm in a good mood today so let me post the link for you FI
http://www.pettitracing.com/rx8/index.htm
Old Apr 18, 2011 | 12:13 PM
Jethro Tull's Avatar
Living In The Past
Bump.
I've pulled and pulled and the factory **** is ON THERE. I even warmed it with a blow dryer until it was almost too hot to touch, didn't help.
I'd sure like to install my rotor radio ****, but if I pull that thing any harder, I'm worried about damaging the switch.
Any new ideas in the last 4 years?
Old Apr 18, 2011 | 01:38 PM
AJRx892's Avatar
One side of the shaft is flat so therefore twisting won't help and when I replace the LEDs for blue ones the **** was extremely hard to get off prying won't work because the **** is deep on the sides It just takes some grip and well to pull straight out it's difficult to do and hopefully the thing it's attached to doesn't come out with it since it's attached to the board
Old Apr 19, 2011 | 11:08 AM
Living In The Past
I've pulled the **** as hard as I can without actually putting a pair of Vise-grips to it. Won't budge a millimeter. I even snaked some steel wire under it and pulled the ends with pliers. Again, it won't move.
At this point I'm considering taking a Dremel to it. If I cut away the outer portion of the ****, I'll have easier access to the hub.
Old Apr 19, 2011 | 11:13 AM
laythor's Avatar
I zoom therefore I am.
+1 for the dremel
Old Apr 19, 2011 | 11:34 AM
Living In The Past
Originally Posted by laythor
+1 for the dremel
In keeping with my policy of holding-onto upgraded stock parts, anybody want to sell me their stock radio ****, for when I've dremeled the old one off?
I think it might be a good idea to keep the shop vac going, right next to the **** as I grind it away, to keep the plastic swarf from getting into the Bose.
RX8mzda
Oct 1, 2015 10:17 PM
ShellDude
Oct 1, 2015 09:55 PM
archon
Oct 1, 2015 06:08 AM
Learners_Permit
Sep 27, 2015 07:38 PM
