anyone replaced the oil pressure gauge
Old Sep 22, 2005 | 03:54 PM
Baywatch's Avatar
has anyone replaced the stock oil pressure gauge with one that actually works?
I don't want to add an additional gauge..
Old Sep 22, 2005 | 03:58 PM
TownDrunk's Avatar
I am a meat popcicle
Great question. I'm curious too.
Old Sep 27, 2005 | 01:51 PM
Baywatch's Avatar
Old Oct 3, 2005 | 03:19 PM
Baywatch's Avatar
bump?
Old Oct 5, 2005 | 09:12 PM
DarkBrew's Avatar
Extraordinary Engineering
I am interested too. While replacing the oil pressure guage how about we add oil temp?
Old Oct 5, 2005 | 09:41 PM
DARKMAZ8's Avatar
"Call me Darkman"
Just get a gauge pod.
Old Oct 8, 2005 | 04:55 PM
epitrochoid's Avatar
Riot Controller
The new miata's have a functional oil pressure meter ...I heard also that it was easy to adapt older mazda's to a functional gauge instead of an idiot light
Old Jul 11, 2007 | 11:09 PM
MPG > HP's Avatar
Bump to find out if anyone has been able to replace the stock oil pressure and water temp gauges with analog ones. Would want them in the stock location (not pod) with real psi and F markings. What about mounting analog gauges with only the needle indicators showing and using decals to show psi & F?
Old Jul 12, 2007 | 12:24 PM
bureau13's Avatar
I had hoped at one point that the oil pressure switch could simply be replaced by a proper oil pressure sensor, and that the gauge would read it..the problem starts with the sensor, because there really isn't one...just a switch. However its more complicated than that. The gauge itself is part of the whole dash pod, which can be viewed as this single electrical entity. The signal from the oil pressure switch is an input to the electronics that control the gauges, and the "brain" if you will controls the gauge. I assume there is a similar function going on with the water temp, although given the fact that a real sensor is used, there may be some hope in that department.
jds
Old Jul 13, 2007 | 01:07 PM
evilmiata's Avatar
^^^The older Miatas had a similar issue. However, the cluster relayed whatever signal came from the oil pressure sender. All we had to do was swap the sender and gauge and *bam*: accurate oil pressure.
Hmmmm.
Old Jul 13, 2007 | 01:53 PM
marceldwayne's Avatar
why do they even have an oil gauge in the rx8 if the thing doesn't accurately measure the oil.
Its actually misleading and i almost didnt add more oil because of it.
Old Jul 13, 2007 | 04:05 PM
bureau13's Avatar
Even it if worked "properly" you wouldn't want to use it to tell you when to add oil. Its a pressure gauge, not an oil level indicator. There is one of those (the light) too.
Basically, you may think of our oil pressure gauge as an idiot light masquerading as a pressure gauge, because that's basically what it is.
jds
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
vetteor8
Aug 9, 2015 05:56 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
