mazda speed wing brackets
Old Sep 21, 2005 | 12:45 PM
Rev0lutionRX8's Avatar
Red Rocket
i was wondering if anyone knows some were i can purchase a set of replacement brackets for my mazda speed wing unfortunatly i guess the bass in my car has caused the brackets to crack now i need to find somewhere to buy a replacement set and the vendor from which i originally purchased the wing from does not sell the actual brackets i need , which are the 2 silver brackets that connect the actual wing to the base if any one has any suggestions on where i can purchase them please let me know
Old Sep 21, 2005 | 01:27 PM
alnielsen's Avatar
How about finding a machine shop that can fabricate you a new set?
Old Sep 21, 2005 | 01:39 PM
BIU's Avatar
BIU
they are solid metal brackets....... i cant imagine your bass cracking them...
Old Sep 21, 2005 | 02:05 PM
KYLiquid's Avatar
Oil Injection
defect in the metal is my guess. Or its a knock off wing with plastic brackets.
Old Sep 21, 2005 | 02:31 PM
Red Rocket
i wish i could say it was a replica because maybe then i wouldnt be as upset..... lol but the problem is that my passenger side bracket keeps getting loose because aparently the threads are worn down i guess due to continous tightening of the boltsdue and constant vibration and rattleing due to the bass where my passenger side bracket cracked along were the bolts go threw so thats why i figured i would just try to replace them with a new set.... yes they are a metal compound that is why i am amazed they cracked as well....
Old Sep 21, 2005 | 02:34 PM
Wow, this is quite disturbing news.
I just installed the MS wing yesterday and was planning on installing two 4080 boxes.
Have you tried calling Mazda about it? If they dealer installed it for you, it should be covered under warranty, no?
Old Sep 21, 2005 | 02:40 PM
Red Rocket
the problem is its a oem Mazda Speed Wing But i didnt purchase it through the dealer i purchased it from a authorized MS retailer in miami and they dont sell just the brackets they sell the whole setup.... and because i had it installed when my body kit was installed being that it wasnt done at mazda they wont warranty the brackets cause they didnt install it so theyre saying that i may have stressed the brackets in the install process... which is total bull.....
Old Sep 21, 2005 | 02:42 PM
Red Rocket
i mean im sure i can find some place online that will sell just the brackets even if they are replica brackets im just scared one day my spoiler is just going to fly off while im driving or somthing so im trying to correct the problem before it gets worse....
Old Sep 21, 2005 | 02:49 PM
KYLiquid's Avatar
Oil Injection
the part comes with a mazda warrenty, id talk to the dealer, also if its just the bolts, you can go to a good hardware store, or a place like House of Threds here in orlando and find a nut/bolt combo that works for you and looks stock.
Also if its just the bolts on the bracket and there is still enough thred left to screw it together, get some LOCK-TITE blue, if you want to be able to un-screw it again, or LOCK-TITE read if you want it to be together FOREVER! just make sure you wipe up any drips.
If the braket itself it cracked, a good metal shop could weld it together and then polish it, it would look good as long as your a few feet away, then if you not happy you could get it powder coated body color, or light silver or black or wahtever you want.
Thats my $.02
Old Sep 21, 2005 | 03:15 PM
Red Rocket
thanks for the great advice KY but ya it is the bracket that has lost its thread and is cracked i was thinking of some lock tite but when it comes down to it i was just hopeing to find some 'vendor that could sell me a set of brackets being that it is cracked ....but if i have a problem getting a new set then i just may follow your advice....
Old Sep 21, 2005 | 04:55 PM
KYLiquid's Avatar
Oil Injection
i know feed makes extensions so the wing can be mounted higher, unfortunetly these attach to the stock brackets, but i bet you can find an after market company that makes totaly new ones.
Old Sep 21, 2005 | 10:53 PM
Kel Rx8's Avatar
if your not 1st your last
I can make a set of fiberglass ones maybe in 2 weeks when I get some time(unless hurricane rita makes real damage) for you
I have fiberglass ones from my ms wing and just posted my new JL system may blow my wing off.
Old Sep 21, 2005 | 11:40 PM
RX-Hawk's Avatar
wtb F/I
One of my height adjustment bolts came loose and was lost, had to buy replacement one at home depot. A friend of mine had the bolts underneath the wing missing shortly after he had his mazdaspeed wing put on. Now my mazdaspeed side skirt is missing a freaking screw on the front so it was slightly loose. I bought the screw from home depot that was as close as possible to the mazda one, but it wont stay in tight. Why cant mazda make availble the bolts/screws for this kits since obviously several people are having problems with them >(
Old Sep 22, 2005 | 06:41 PM
Kel Rx8's Avatar
rosenthal sells hardware kits for sides.I just got my passenger side hardware today.
gwilliams6
General Automotive
Sep 10, 2015 02:22 PM
fireishot34
Aug 20, 2015 11:58 AM
kdoiron08
Aug 15, 2015 02:17 PM
AussieGray
Jul 16, 2015 03:58 AM
