BigOLundh
09-16-2005, 04:38 PM
Currently we have 7 leading, and 9 trailing in our stock RX-8s. Has anyone put 9's in the leading? The depth of the plugs seem different so I was just wondering if anyone has had problems or seen damagae with using the 9s where the 7s were.
Now that i'm running boost i'd like to put colder plugs. Thanks for the help.
-hS
MadDog
09-16-2005, 10:45 PM
I think they are different depths. I am running the Denso Iridium plugs. They are the only colder plugs I could find. $37/per is a pretty price though...
BigOLundh
09-17-2005, 08:50 AM
Thanks MadDog...
Anyone else doing this as well?
Fanman
09-17-2005, 12:47 PM
I had the 8's originally. Worked like a charm. Seemed identical to the 7's. Canzoomer sells them. Now I am on Denso's trailing & leading.
RotorManiac
09-17-2005, 07:07 PM
Greddy racing plugs here, RE10
I know, very cold plugs, but it works smoothly. have them on for 10k miles now... it cranks better than stock too...
drifter_d
09-17-2005, 07:20 PM
very good topic. i've been mulling over the question of which plugs to go with, as well. appreciate all the feedback from those with aftermarket plugs.
dd sends...
MadDog
09-18-2005, 01:06 AM
anyone pulled their cold plugs to check the fouling situation yet?
-MD
MadDog
09-19-2005, 01:05 PM
I checked with NGK about two months ago. I knew Manuel was running them, but apparently we can't get them in the states. They had no part number for the US, but said they would be released here soon.
-MD
RX8PR
09-19-2005, 06:41 PM
NGK part no R6725-105
I was thinking that any one can buy this sparks on the states............because usually the sparks that the distributor sales in PR came from USA. But if you can't find them in the states you can buy them here and send them to the states thru priority mail, UPS, Fed eX, etc. they also sell colder one's.
Manuel
RX8PDX
09-19-2005, 09:49 PM
What would the benefits be of running colder plugs?
Fanman
09-20-2005, 01:42 AM
Reduce detonation at higher boost levels.
