lights in the Engine Bay
Old Sep 15, 2005 | 11:02 PM
8 is enough's Avatar
has any one tried putting some lights in their engine bay? If so does any one have pics
Old Sep 16, 2005 | 02:06 PM
wedge357's Avatar
ShinkaMan #748 SV6P
Probably somebody can do a DIY on this??? I'm interested. Parked in my garage the overhead lights don't quite go right over the hood. I can hook-up an extension light but for a quick oil check a hood light can come real handy.
Old Sep 16, 2005 | 02:48 PM
KYLiquid's Avatar
Oil Injection
I plan on installing a light, more than likely an LED, im gonna make it so it shines on the side around the oil dipstick, so it makes it easyer to check the oil in low light....like at night at a gas station it cna be hard to see where to put the dipstick. I want to tie it into the same circut so when the doors are open it triggers the light. Radio shack sells the 12v BRIGHT white leds, should work good.
You can easily run the 2 wires for it thru a gomet in the firewall, and hid the wires under the insulated pad in the engine bay....and since my light would be on the 'cold' side of the motor, it would be protected and hidden well....
I am gonna tackle that this weekend. Ill post back!
Old Sep 16, 2005 | 07:16 PM
wow i was thinking something similar to what you are doing
Old Sep 16, 2005 | 08:56 PM
Kel Rx8's Avatar
if your not 1st your last
u want some neon tubes in there for show right ?
Old Sep 17, 2005 | 06:49 AM
Huhwha's Avatar
How about with a plunger switch so it goes on when you open the hood?
I've been thinking about this for a while, but haven't gotten to it yet.
Old Sep 17, 2005 | 03:41 PM
nice add on idea
Old Sep 17, 2005 | 04:53 PM
LiL BenNy's Avatar
Bubblicious? DEF.
anyone got lights showing through a vented hood?
Old Sep 19, 2005 | 10:42 AM
devoid's Avatar
My doctor prescribed RX-8
Well, I've got some underhood lighting. There's one light in the airbox, and two under the plexiglassed engine cover. There is also a flood light mounted up in the hood that sheds light onto the entire engine bay.
Also, not a vented hood, but I have some pics of the lights that shine through the grilles.
For more pics, you can check out the site: http://rx8.mine.nu
Attached Thumbnails lights in the Engine Bay-underbody_lights_14.jpg   lights in the Engine Bay-engine_bay_02.jpg   lights in the Engine Bay-engine_light_01.jpg   lights in the Engine Bay-engine_light_03.jpg
Old Sep 19, 2005 | 11:12 AM
how bout a regular light? Maybe some small 194 bulbs?
Old Nov 5, 2005 | 07:49 AM
BoosTED's Avatar
DIY Dipstick light
I just finished installing my dipstick light.
1 minute install.
Push button switch is the chrome piece opposite of the bulb.
Funny thing is I was going to rig up a switch in side and run wires to a couple of satellite LEDs had them picked out and spent like 15 minutes trying to choose a switch and then decided to get the 3 LED instead of 2. Buried next to them was this wireless LED with a clip on one end and a push button switch on the back.
Brighter than I had expected too.
Attached Thumbnails lights in the Engine Bay-dsc00359.jpg   lights in the Engine Bay-dsc00360.jpg   lights in the Engine Bay-dsc00357.jpg
Old Nov 5, 2005 | 11:14 AM
truemagellen's Avatar
Attracts tree branches
nice!
Old Nov 22, 2005 | 10:24 AM
Huhwha's Avatar
Did anybody ever finish this? I want to light up the engine bay, mostly around the dipstick tube, but enough light to see everything else too. I want it to work off a plunger switch, so when you pop the hood, the light comes on. I will have some time over the holidays to do this, but I don't need to re-invent the wheel. Any thoughts?
Old Nov 22, 2005 | 10:33 AM
BoosTED's Avatar
Almost Christmas time, wire in a string of Christmas lights.
Just dawned on me, perfect for undercar lighting.
Seriously though the LED clip on light has been great, very bright, and hasn't moved off a bit even with very spirited driving. $5 at Target, in Red gift box.
Quick install, lightweight.
Nice thing is it can be moved and adjusted where you want to see. I leave the corded shop light on the bench now. Grab the clip light work under the dash is easy, no flourescent light headache either if working for hours.
Old Nov 22, 2005 | 11:27 AM
Huhwha's Avatar
OK for 5 bucks I'll give it a shot tomorrow.
BigMikeATL
May 26, 2016 12:31 AM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
